It is currently Fri Jul 18, 2025 6:56 pm
 Post subject: Engine number
PostPosted: Wed Aug 30, 2006 8:43 am
I cant find the engine number on the Mokes engine. I have looked all over and cant find it.
Any suggestions?
PostPosted: Wed Aug 30, 2006 9:04 am
Should be in the same place as the Mini I would have thought - stamped on the block near #1 cylinder. Has your block been decked???? Maybe the engine number has been shaved off in the process.
Hooroo
Rod Image
PostPosted: Wed Aug 30, 2006 9:05 am
Dont know if its been decked, but I will look near 1 and 4 in case I have cylinder numbers wrong.
PostPosted: Wed Aug 30, 2006 9:13 am
CLean off whatever paint etc is there with some sandpaper or emery cloth on a flat board (swipe your wife's nail file ....) gently and if there's any indentation left it will gradually show up by the very thin layer of paint trapped in them . Just make sure you sand/file it gently and the board is flat . It'll be easier to do with the head off but still possible with the head on .
PostPosted: Wed Aug 30, 2006 7:19 pm
Radiator end near the Temp Sender location
PostPosted: Thu Aug 31, 2006 7:36 am
Found it thanks.
