It is currently Tue Jul 22, 2025 11:01 am
 Post subject: Hot Engine
PostPosted: Thu Aug 31, 2006 12:12 pm
When the engine is running a little hotter than normal (ie: in heavy traffic) when i go to take off from stand still it seems as the fuel is vaporising before it actually gets to the cylinders.
I say this because when i attempt to move off, the car almost wants to stall, but if i rev it higher and ride it out no probs... The car is fine when cold or normal operating temp.
Can fuel evaporate from heat in the manifold???
Thanks people.
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
PostPosted: Thu Aug 31, 2006 12:15 pm
Always did that when i had it, too...
PostPosted: Thu Aug 31, 2006 12:38 pm
running lean makes the car run hot... check the mixture...
PostPosted: Thu Aug 31, 2006 1:10 pm
Vapour lock
Electric Fuel pump
No More Vapour Lock.
J
PostPosted: Thu Aug 31, 2006 1:18 pm
Its already got a 'leccy SU-type pump off an MGB. Seemed to feed the weber/1293 fine :?
PostPosted: Thu Aug 31, 2006 1:23 pm
I replaced the spark plugs on the weekend, haven't driven it in traffic yet, but the old N9YX's were black on the tips and threads... I thought that indicated rich mixtures :?
Santo
"The Lone Ranger"
PostPosted: Thu Aug 31, 2006 1:45 pm
Its was dyno'd about a month before you got it. I tried NGK plugs, but they fouled up pretty quick. Useless for stop/start driving.
The ol' Champion N9Y's worked much better. Never had a problem with them.
What plugs are you running now?
PostPosted: Thu Aug 31, 2006 1:47 pm
i think its the NGK 6BPES that is the best for a mini they dont foul up like the cooler plug does
PostPosted: Thu Aug 31, 2006 2:06 pm
BP7ES from memory... I asked for a colder plug than the equivalent of the N9Y's which is the the 6ES like Chris said.
Santo
"The Lone Ranger"
PostPosted: Thu Aug 31, 2006 2:07 pm
Could be the problem. Cooler plugs will foul easier...
PostPosted: Thu Aug 31, 2006 2:09 pm
I've only just put these plugs in... I haven't driven the Mini since Saturday night when i had the problem. Plugs went in Sunday.
Santo
"The Lone Ranger"
PostPosted: Thu Aug 31, 2006 4:41 pm
the 6ers are a hotter plug i beleive
PostPosted: Thu Aug 31, 2006 6:00 pm
Yes, thats why i bought the 7ES's, i was told they were one colder than the 6's...
Still... The above mentioned problem happend before i changed the plugs, basically, the same components that were in the car when i bought it.
Santo
"The Lone Ranger"
PostPosted: Thu Aug 31, 2006 7:48 pm
If it was fouling with 6ES you need a hotter plug, not colder. Try BP5ES. :wink:
Note NGK's plug numbers are arse-about compared to Champion (or Bosch).
Hotter
Champion N11YC = NGK BP5ES = Bosch W8DC
N9YC = BP6ES = W7DC
N6YC = BP7ES = W6DC
Colder
PostPosted: Thu Aug 31, 2006 7:56 pm
if your running unleaded and even more so premium unleaded you will need to run a hotter plug, BP5ES, for the simple fact that unleaded petrols have a high combustion point to the old stuff. The higher the Ron the higher the flash point. Hotter plug is needed to get a hot enough spark to ignite all the fuel in the cylinder, otherwise you get black sooty plugs.
Aaron
