twin carbies https://www.ausmini.com/forums/viewtopic.php?f=2&t=22232 |
Page 1 of 2 |
Author: | Dwayne [ Tue Sep 05, 2006 9:40 pm ] |
Post subject: | twin carbies |
hey i was just wandering if someone knows where i can get a set of secondhand twin carbies from in adelaide? |
Author: | scotta_74 [ Wed Sep 06, 2006 12:00 am ] |
Maybee in the wanted section???? ![]() |
Author: | Mick [ Wed Sep 06, 2006 12:03 am ] |
EBAAAAAYYYY!!!! (Especially the UK one..) |
Author: | sumanovic [ Wed Sep 06, 2006 12:11 am ] |
Mick wrote: EBAAAAAYYYY!!!!
(Especially the UK one..) he wanted in adelaide...if possible i gues ~sumanovic |
Author: | Mick [ Wed Sep 06, 2006 12:23 am ] |
Quote: he wanted in adelaide...if possible i gues
oh..oops....Auspost deliver to Adelaide?? |
Author: | Wombat [ Wed Sep 06, 2006 8:52 am ] |
Couple on the UK eBay at the mo but a bit pricey ![]() |
Author: | pristic [ Wed Sep 06, 2006 9:02 am ] |
What, 1.25's? Twins or bowls on same side? Peter. |
Author: | 1018cc [ Wed Sep 06, 2006 4:52 pm ] |
Post subject: | Twin Carbs |
I bought some twin 1.25" HS2 carbs off eBay and would recommend it (if you can find a decent seller). My guy said he got them off a mini (yeah right unless it had a hole hacked in the firewall) and said they would bolt straight up (on the listing it said that) but when I got them I found they were off a Morris Minor or something (that has the north south A series) and the inlet manifold was too long to fit with out chopping the firewall and the carbs had the numbers followed by F and R.....(front and rear NOT L(eft) and R(ight) for a mini). Was bit peeved off but I got them for the right price and they were in pretty good nick. I did however get them rebuilt for piece of mind because just about any set you get will have worn shafts, but other than that they are brilliant. You REALLY notice how asthmatic a single 1.25" is! Go eBay and specifically ask for the numbers on the float bowls and see if they end in L and R. I'd still recommend it though. |
Author: | WiLo [ Wed Sep 06, 2006 5:01 pm ] |
little bit OT but still dual carb related i ahve two carbs in my posession atm, but they are the same side, what linkages manifolds etc. do i need to run dual carbs? |
Author: | 1018cc [ Wed Sep 06, 2006 5:06 pm ] |
Post subject: | Twin carbs |
I'm not sure what parts you need for twin carbs but I know people who have done it (it was quite a while ago and can't remember what they did). I'm SURE someone on here will know the information you're looking for. Its a cheap worth while up-grade. |
Author: | drmini in aust [ Wed Sep 06, 2006 7:20 pm ] |
All you need to join them is a bit of 5/16" dia steel shafting, and a couple of W-clamps from your local carby shop. Morris 850 Sports had this setup, so did countless aftermarket kits for Minis and 1100s from Warneford, Lynx, Peter Manton, etc. ![]() |
Author: | Morris 1100 [ Wed Sep 06, 2006 7:33 pm ] |
drmini in aust wrote: Morris 850 Sports had this setup, so did countless aftermarket kits for Minis and 1100s from Warneford, Lynx, Peter Manton, etc. BMC also sold these kits as accessories at their dealers. ![]() ![]() |
Author: | 64mini [ Wed Sep 06, 2006 7:37 pm ] |
I like to see a pic of the two W-clamps and rod as I am wanting to join tow carbs up. |
Author: | ELMO [ Thu Sep 07, 2006 1:39 am ] |
Nothing beats a big pair of jugs to look at. er I mean a pair of 1.5 inch su's |
Author: | marklh [ Fri Sep 08, 2006 8:16 pm ] |
Post subject: | TWINS |
I believe mini sport in adelaide have a set of 1.5 SU available now, Talk to Tony. Marklh |
