3 clock gauges - different tachos? - MYSTERY SOLVED
https://www.ausmini.com/forums/viewtopic.php?f=2&t=22354
Author:  FatMaserati [ Fri Sep 08, 2006 10:07 pm ]
Post subject:  3 clock gauges - different tachos? - MYSTERY SOLVED
My tacho looks like this from the back.
Other tachos look like this, with an extra (+ve?) connection...
WHAT'S THE DEAL WITH THAT!?
Also, the light thats at the bottom of the speedo is the light that's not used, right?
Author:  slinkey inc [ Fri Sep 08, 2006 11:11 pm ]
Im not 100% sure about your questions but, I got my triple guage thing from a 1275 LS, I believe they can be used for (becasue on my car there are two unsed one on tacho one on speedo) Handbrake? and Brake failure warning light for mini's with dual brake cylinders. Being about a '78 this would make sense. OH and I got my coil line attached to that 'extra' +ve? thing. It works so I'll leave it.
Author:  Razor [ Fri Sep 08, 2006 11:23 pm ]
FatMaserati
hey that's my 3 clock gauge!
mine still not working, right now I'm assuming the tacho itself is dead
Author:  YoungMiniac [ Sat Sep 09, 2006 12:30 pm ]
My gauges look the same as the top one and I was thinking if anything was missing when i saw Razor's picture....
Author:  GT [ Sat Sep 09, 2006 6:56 pm ]
77/78 Clubman with CLIP ON speedo cable (white needles) had one type of tacho, and all earlier Clubmans with screw on speedo cable had the other type.
can't remember which one goes with which, but yea...I got caught out once when swapping them around.
Author:  Razor [ Sat Sep 09, 2006 8:52 pm ]
mines a clip on
the other type is for the screw on then?
Author:  FatMaserati [ Sat Sep 09, 2006 8:56 pm ]
Ahh, see, mine's a screw on. So there you go. Mystery solved.
Thanks GT.
Author:  Razor [ Sat Sep 09, 2006 8:58 pm ]
your printed circuit looks exactly like mine (the mapping)
Author:  FatMaserati [ Sat Sep 09, 2006 9:06 pm ]
Yeah im fairly sure the printed circuit is the same. My pc might have been from a later model one, as it originally had that circuit for the extra tacho terminal.
Author:  Harley [ Sat Sep 09, 2006 9:11 pm ]
Maserati, what year is your cluster from (approximately)?
:D
Author:  FatMaserati [ Sat Sep 09, 2006 9:18 pm ]
Your guess is as good as mine, harley. Heh heh :lol:
Author:  Harley [ Sat Sep 09, 2006 10:02 pm ]
We'll go for the obvious then. Is it from a clubby or a rover? :D
Author:  FatMaserati [ Sat Sep 09, 2006 10:24 pm ]
Definately a Clubby
