Cones, old and new https://www.ausmini.com/forums/viewtopic.php?f=2&t=22416 |
Page 1 of 2 |
Author: | Zizzle [ Mon Sep 11, 2006 3:47 pm ] |
Post subject: | Cones, old and new |
It's nearly time to start putting my subframes back together. I've got a few old rubber cones laying around. Don't know whether to lash out on a new set. One pair out of a rear subby is about 82mm high, another set also out of a rear subby is 77mm. Ones out of front subby are event shorter as expected. So the question is, what should the threshold be for throwing away? I had initially been offered to sort through a large pile of old cones and find the best, but I believe that offer no longer stands. At the moment I'm thinking about maybe buying a new pair, and using the best of the old ones. What would be the best: old ones in the front or the back? (and yes I have hi-los) What are the experiences of people who have bought new ones? Happy? Worth it? Does anyone know where to get them cheaper than $100 each I have been quoted? |
Author: | drmini in aust [ Mon Sep 11, 2006 4:01 pm ] |
Look at the shape- if they have gone fat where the cone fits, they are past it. Should be a single curve to the outside shape. Anton has a pic of both on here, somewhere...... ![]() |
Author: | JC [ Mon Sep 11, 2006 4:38 pm ] |
Post subject: | Re: Cones, old and new |
Zizzle wrote: It's nearly time to start putting my subframes back together
HAAAAlayluya, Halayluya, Halayluya. HAAAAlayluya, Ha La EEEE Lu Yaaaaaa. In all honesty, what are you going to pay for four new cones? $250 ish, then $500 for decent shockies. My money would be on a set of coilovers. Do the car justice. |
Author: | Matt68 [ Mon Sep 11, 2006 5:13 pm ] |
You gets what you pays for. Get genuine rubber cones, stick a new pair in the front and the best of the old ones in the rear. Avoid coilovers, they are not a step up, and mini subframes/ body are not designed to take the stresses. (Coilovers + Mini = Good = MYTH) For real suspesion, go hydro! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | Blokeinamoke [ Mon Sep 11, 2006 5:44 pm ] |
Also watch out for crazing. Ozone depletes the rubber and makes it fail. Bahave like bending an eraser in half. This is caused by age. So old rubber anythings should be inspected for cazing not just the shape. |
Author: | Morris 1100 [ Mon Sep 11, 2006 6:55 pm ] |
My vote is new cones all round. ![]() |
Author: | gafmo [ Mon Sep 11, 2006 7:25 pm ] |
I would New cones in the front and wind the HiLo's as low as you can and the talest of the old (after Inspection) in the rear. Atleast if the rears seams to low they are the easiest to remove and replace Okay can someone measure what hight new one are.. Please ![]() |
Author: | GT [ Mon Sep 11, 2006 7:40 pm ] |
Matt, new cones in the front and old ones in the back will DEFINITELY make the front too high. This happened to me and I had to buy Hi-Lo's to fix the problem. If you have the money, buy genuine new cones all round. Don't do one end and not he other. |
Author: | justminis [ Mon Sep 11, 2006 9:21 pm ] |
striped 63 wrote: [quote="In all honesty, what are you going to pay for four new cones? $250 ish .
Where can you get 4 new cones for $250.00 ish?? |
Author: | Mini Mad [ Mon Sep 11, 2006 9:29 pm ] |
MinisportSA have them for $220 a pair.. http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=190028820457&ssPageName=STRK:MEWA:IT&ih=009 New vs OLD on eBay Here are my New ones vs OLD ![]() |
Author: | willy [ Mon Sep 11, 2006 9:32 pm ] |
Joshua, you have focussed on the background, not the topic ![]() ![]() |
Author: | Mini Mad [ Mon Sep 11, 2006 9:38 pm ] |
You get the idea ![]() |
Author: | Mini Mad [ Mon Sep 11, 2006 9:39 pm ] |
Does Karcraft sell new cones?? |
Author: | JC [ Mon Sep 11, 2006 10:16 pm ] |
justminis wrote: striped 63 wrote: [quote="In all honesty, what are you going to pay for four new cones? $250 ish . Where can you get 4 new cones for $250.00 ish?? $500 ish then, all the more reason not to buy them. |
Author: | Harley [ Mon Sep 11, 2006 10:32 pm ] |
I'm in the same position with subframe assembly. For a comparison, what is the height of the cones found in those photos? ![]() |
