It is currently Mon Jul 21, 2025 3:15 pm
 Post subject: PCV Valve
PostPosted: Wed Sep 13, 2006 8:25 pm
Just wondering is it possible to use a generic PCV valve off another car make for the mini?
I was advised to use a holden valve by a mini workshop :shock:
I know you can buy these new but its kinda expensive and just want to know 1st if there's an alternative way.
PostPosted: Wed Sep 13, 2006 8:30 pm
Most other PCVs do not go straight into the inlet manifold like the Mini one does. Many go to a connection on the carb's throttle, eg on downdraft Webers (Fiat, etc).
So they don't have the diaphragm valve thingy which regulates flow vs vacuum level.
