It is currently Mon Jul 21, 2025 4:21 am
PostPosted: Sun Oct 10, 2004 7:03 pm
well i was reading a mini mag and it had a car with a 1380 and the reporter said that block being bored to 1380 bought the block to be closer to squarer giving a smoother idle
IS this fact less meet in between the cylinders the smoother the idle :?:
PostPosted: Sun Oct 10, 2004 7:16 pm
Sounds like BS to me... :shock:
Whether it idles smooth or not depends on many things, but boring it to +.115" isn't one of them, IMO.
PostPosted: Sun Oct 10, 2004 7:25 pm
yeah i thought so i know there are a number of variables which need to come together to give an engine a smooth idle but was just wondering if boring the block was one
PostPosted: Sun Oct 10, 2004 10:09 pm
Guys it is not the bore size alone that makes the difference but it is in fact the capacity of the cylinder, whether it is bored or stroked. The increased capacity of the cylinder changes the rate at which air is drawn past the valves due to the expanding chamber's negative pressure. Conversely you can run a cam with larger overlap and greater lift to take advantage of the the greater vacuum phenomenon, and there is proportionately less residual gas in the chamber, giving less of an affect on idle. This is one of the reasons why large cc engines can sometimes (and I mean sometimes because of all the other variables) run with a smoother idle on the same given cam.
1962 Mini Speed sports sedan
PostPosted: Mon Oct 11, 2004 9:55 am
ahh ok thanks for that now i understand what he meant
Users browsing this forum: Bing [Bot] and 81 guests
