It is currently Tue Jul 29, 2025 10:41 am
PostPosted: Sun Sep 17, 2006 4:32 pm
Hi my mini is leaking fuel from what i believe is the pump (not sure) it has two pipes going into the top, on the top it has 2 black circles one with a '+' and the otehr with a '-'.
To me it looks like it is comming up through the top of that (like lid is broken or something) I have replaced the pipes and tightened all the pipe clamps to make sure they are not leaking, but have concluded it is that thing...
I would like to know what that thing is and if it is a common problem. And of course how to fix :D
Sorry can't get a picture you will just have to try and understand what I am saying :P
All help appreciated, Thanks Ian :)
Ian - My Ve SSV Ute - Looking for a Mini
PostPosted: Sun Sep 17, 2006 4:36 pm
swap to an electric feul pump, i remember you saying ages ago you could smell feul, i cansmell feul in my mini aswell and i am 145.65% sure that its coming from the breather hole in the top of the tank,
PostPosted: Sun Sep 17, 2006 4:40 pm
So it's the fuel pimp?
PostPosted: Sun Sep 17, 2006 4:44 pm
That sounds like it already has an electric fuel pump. + being positive and the - being negative for the motor inside the pump. Where abouts on the car is this thing located?
PostPosted: Sun Sep 17, 2006 4:45 pm
it is behind the engine, I think the '+' and '-' is just for in and out pipes, not sure tho...
PostPosted: Sun Sep 17, 2006 4:53 pm
Is there any electrical wiring going to this unit?
PostPosted: Sun Sep 17, 2006 4:58 pm
Don't believe so, will check...
But my only answer is buying a new one??
Ian
PostPosted: Sun Sep 17, 2006 5:52 pm
No wires going to the fuel pump....
 Post subject: pimp it!!
PostPosted: Sun Sep 17, 2006 6:04 pm
Is it sorta made out of glass stuff....may be a fuel filter :?: :idea:
PostPosted: Sun Sep 17, 2006 6:09 pm
I searched fuel pump on eBay ;) lovely internet and the pictures match what is leaking on mine....
PostPosted: Sun Sep 17, 2006 6:20 pm
if its a mechanical fuel pump you can take it off, pull it apart and clean it out, and put it back together with fresh gaskets.
 Post subject: Gaskets
PostPosted: Sun Sep 17, 2006 8:13 pm
If its leaking from the top cover....replace the gasket.
You shouldn't have to remove it from the block....that gasket would be leaking oil.
Users browsing this forum: No registered users and 114 guests
