After spending 2 hrs yesterday with some pliers, and then 3 hrs today with 2 trips to bunnings (1st for a small long hole punch, then for a small loooong drill bit) and then finally removing the f*6cuking split pin so that I could get the clevis pin out (FOR THE LOVE OF GOD USE R CLIPS PEOPLE), I went under the bonnet and started to undo the pressure line.
Of course it looked 300 years old and didn't want to budge without twisting the pressure pipe with it so I wd40'd it and waited a bit and then gently put some pliers onto the pipe and proceeded to undo the nut, still the little bastard snapped clean off
Gunna spend what's left of the afternoon rekitting the clutch master, but anyone had this happen to them? I've been told to check out a few brake places as apparently they'll make the pipe up for me (?). Other then that what are the chances of me finding one off another cylinder? (i'd ring around but everything's closed at this hour).
I'm sort of glad it snapped though, if the pipe was that badly rusted onto the bolt it'll be good to fit it with something clean.
Shard
