It is currently Sun Aug 10, 2025 5:23 pm
 Post subject: few undercar questions
PostPosted: Sat Sep 16, 2006 8:10 am
so i had a safety check and this is the list of things that it says on y receipt that arnt up to scratch:
play in front lower shock bushes
front upper control arm inner bushes
right outer cv boot torn
caster bar front bushes
play in left hand front wheel bearing
lower control arm inner bushes in front.
and needs left rear wheel bearing adjustment
and then i went to get rego check yesterday at another place where all he does is check my lights and drive it around the block for brake test, well its a bit rattly so he jacked up the front and said i need to fix the bushes on the front then he'll pass me.
basicaly im getting my work done at the first place but my question is... because i have little knowledge about these kinda things... with the list what parts will i have to buy and how much will they be before i go back to get it all put in and fixed up, or isnt it enough knowledge for u to work with :roll:
oh and how long do i get after my rego runs out before it rolls over to need a blue slip or any other silly thing?
thanks people.
PostPosted: Sat Sep 16, 2006 10:14 am
ok we'll just try the control arm bushes, what do i need to get for them to fix them?
any help would be appreciated thanks
PostPosted: Sat Sep 16, 2006 11:41 am
IIRC you have three months before you need a blueslip, well thats what im hoping, my rego ran out last week, and the car is currently sitting in the garrage with no motor in it
PostPosted: Sat Sep 16, 2006 2:05 pm
lower control arm bushes from karcraft are about $2.30... tell your mechanic to order what they need from there, or take it to a mini specialist like Mini Classic
PostPosted: Sat Sep 16, 2006 6:57 pm
yeah ,3 months untill you need a blue slip from end of rego date,give the guy's from Newcastle Mini Dismantlers a call they should be able to give you an idea of the price for parts.
Users browsing this forum: Bing [Bot] and 101 guests
