It is currently Fri Jul 18, 2025 10:46 pm
 Post subject: how to?
PostPosted: Fri Sep 15, 2006 11:21 am
hey guys just wondering how easy is it to remove subframe to remove the gearbox and replace?
thanks,
scott
PostPosted: Fri Sep 15, 2006 11:24 am
You're better off pulling the whole engine and gearbox out the top and popping the block off it then. Removing the subframe to get the engine out is a lot more difficult.
-Wasabi
1972 Clubman - Daily Driver
1962 850 - EW1 Powered
PostPosted: Fri Sep 15, 2006 1:30 pm
once the engine is out its fairly easy, if you canfollow a hanes manual. just a few things to watch:
1. buy a flywheel puller
2. re-fitting the oil pickuo o-ring
3. refiting the primary gear seal
um, cant think of the rest... but read the manual and see how you feel about it first.
