Winding window lube https://www.ausmini.com/forums/viewtopic.php?f=2&t=22572 |
Author: | gibovski [ Fri Sep 15, 2006 10:14 am ] |
Post subject: | Winding window lube |
I put a new window regulator on the drivers side of my car. The original one was stuffed and slipping when I got the car. While I was changing the regulator little things like a missing washer or two and worn screw heads told me I wasn't the first person to do this. Now the winder work but takes a bit of force which will eventually screw the new regulator. I figure lubing the the window slides will help but I get the impression the door may be a little warped causing the friction. So what sort of lube does one use on the slides on either side of the windows without putting filth all over the windows? |
Author: | Dylans Clubby [ Fri Sep 15, 2006 10:57 am ] |
probably a little wd40 or similar would do the trick? maybe a tiny smear of vaseline? be careful though, as you want to watch out for the muck |
Author: | dove grey 64 [ Fri Sep 15, 2006 12:42 pm ] |
use graphite, it comes in a black squeeze container. works great and doesnt leave crap everywhere. |
Author: | leyland brother [ Fri Sep 15, 2006 12:47 pm ] |
I've got a stick of DRY LUBE... Haven't had a chance to do it yet though. |
