It is currently Sat Jul 19, 2025 1:50 am
 Post subject: Winding window lube
PostPosted: Fri Sep 15, 2006 10:14 am
I put a new window regulator on the drivers side of my car. The original one was stuffed and slipping when I got the car. While I was changing the regulator little things like a missing washer or two and worn screw heads told me I wasn't the first person to do this. Now the winder work but takes a bit of force which will eventually screw the new regulator. I figure lubing the the window slides will help but I get the impression the door may be a little warped causing the friction.
So what sort of lube does one use on the slides on either side of the windows without putting filth all over the windows?
PostPosted: Fri Sep 15, 2006 10:57 am
probably a little wd40 or similar would do the trick? maybe a tiny smear of vaseline? be careful though, as you want to watch out for the muck
78 Leyland Mini - Prince
PostPosted: Fri Sep 15, 2006 12:42 pm
use graphite, it comes in a black squeeze container. works great and doesnt leave crap everywhere.
PostPosted: Fri Sep 15, 2006 12:47 pm
I've got a stick of DRY LUBE... Haven't had a chance to do it yet though.
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
