how to? https://www.ausmini.com/forums/viewtopic.php?f=2&t=22575 |
Author: | hothead115 [ Fri Sep 15, 2006 11:21 am ] |
Post subject: | how to? |
hey guys just wondering how easy is it to remove subframe to remove the gearbox and replace? thanks, scott |
Author: | WasabiPimpNinja [ Fri Sep 15, 2006 11:24 am ] |
You're better off pulling the whole engine and gearbox out the top and popping the block off it then. Removing the subframe to get the engine out is a lot more difficult. |
Author: | jbeenz [ Fri Sep 15, 2006 1:30 pm ] |
once the engine is out its fairly easy, if you canfollow a hanes manual. just a few things to watch: 1. buy a flywheel puller 2. re-fitting the oil pickuo o-ring 3. refiting the primary gear seal um, cant think of the rest... but read the manual and see how you feel about it first. |
