It is currently Thu Jul 31, 2025 8:16 pm
 Post subject: push button start
PostPosted: Sun Sep 17, 2006 1:50 pm
As I am not to familaiar ith some of the earlier morris models that had "push button startup' can someone explain to me how this process works and to what vehicles was it fitted.Did this eliminate the need for a key(probbably a silly question)and does anyone have a vehicle mini with this fitted. Thanks for your help.
cheers all.
PostPosted: Sun Sep 17, 2006 2:29 pm
The Push Button was instead of the starter solenoid. Basically the heavy power cable ran from the battery in the boot to the starter motor with the push button in the floor at the drivers seat. Pushing the button competed the run and turned the starter over. There is a not so heavy cable coming off the battery side of the switch to feed the rest of the electrics including the "ignition switch" - a keyed switch in the dash that simple turns the power on.
This was the original set up in my 850 which a PO had removed and added a solenoid at the starter - I have removed the addition and am going back to the floor start for no other reason than it was original.
Users browsing this forum: slacko and 95 guests
