Mini Leaking Fuel help needed... https://www.ausmini.com/forums/viewtopic.php?f=2&t=22645 |
Author: | YoungMiniac [ Sun Sep 17, 2006 4:32 pm ] |
Post subject: | Mini Leaking Fuel help needed... |
Hi my mini is leaking fuel from what i believe is the pump (not sure) it has two pipes going into the top, on the top it has 2 black circles one with a '+' and the otehr with a '-'. To me it looks like it is comming up through the top of that (like lid is broken or something) I have replaced the pipes and tightened all the pipe clamps to make sure they are not leaking, but have concluded it is that thing... I would like to know what that thing is and if it is a common problem. And of course how to fix ![]() Sorry can't get a picture you will just have to try and understand what I am saying ![]() All help appreciated, Thanks Ian ![]() |
Author: | buztoy [ Sun Sep 17, 2006 4:36 pm ] |
swap to an electric feul pump, i remember you saying ages ago you could smell feul, i cansmell feul in my mini aswell and i am 145.65% sure that its coming from the breather hole in the top of the tank, |
Author: | YoungMiniac [ Sun Sep 17, 2006 4:40 pm ] |
So it's the fuel pimp? |
Author: | Hanra [ Sun Sep 17, 2006 4:44 pm ] |
Post subject: | Re: Mini Leaking Fuel help needed... |
YoungMiniac wrote: on the top it has 2 black circles one with a '+' and the otehr with a '-'.
That sounds like it already has an electric fuel pump. + being positive and the - being negative for the motor inside the pump. Where abouts on the car is this thing located? |
Author: | YoungMiniac [ Sun Sep 17, 2006 4:45 pm ] |
it is behind the engine, I think the '+' and '-' is just for in and out pipes, not sure tho... |
Author: | Hanra [ Sun Sep 17, 2006 4:53 pm ] |
Is there any electrical wiring going to this unit? |
Author: | YoungMiniac [ Sun Sep 17, 2006 4:58 pm ] |
Don't believe so, will check... But my only answer is buying a new one?? Ian |
Author: | YoungMiniac [ Sun Sep 17, 2006 5:52 pm ] |
No wires going to the fuel pump.... |
Author: | 9YaTaH [ Sun Sep 17, 2006 6:04 pm ] |
Post subject: | pimp it!! |
YoungMiniac wrote: So it's the fuel pimp?
Is it sorta made out of glass stuff....may be a fuel filter ![]() ![]() |
Author: | YoungMiniac [ Sun Sep 17, 2006 6:09 pm ] |
I searched fuel pump on eBay ![]() |
Author: | Spaceboy [ Sun Sep 17, 2006 6:20 pm ] |
if its a mechanical fuel pump you can take it off, pull it apart and clean it out, and put it back together with fresh gaskets. |
Author: | 9YaTaH [ Sun Sep 17, 2006 8:13 pm ] |
Post subject: | Gaskets |
Spaceboy wrote: if its a mechanical fuel pump you can take it off, pull it apart and clean it out, and put it back together with fresh gaskets.
If its leaking from the top cover....replace the gasket. You shouldn't have to remove it from the block....that gasket would be leaking oil. |
