Fitment of 850 doors to a windup door-ed Morris
https://www.ausmini.com/forums/viewtopic.php?f=2&t=22693
Page 1 of 2
Author:  willy [ Mon Sep 18, 2006 9:08 pm ]
Post subject:  Fitment of 850 doors to a windup door-ed Morris
Ok.
Pretty simple question.
What needs to be done to get 850 doors on a windup Morris?
I have a Matic that (of course) has windup window doors (well it doesnt have any doors at the moment) and I'd like to fit 850 doors in keeping with my theme for the car.
What needs changing?
Striker plate?
Door seals?
Author:  hutto [ Mon Sep 18, 2006 9:25 pm ]
..okay what you do is attach the hinges :wink:
Author:  willy [ Mon Sep 18, 2006 9:26 pm ]
Righto smart arse.
Now can anyone tell me what else I need to do?
Are there any modifications needed?
Author:  hutto [ Mon Sep 18, 2006 9:28 pm ]
.. oh this is where it gets tricky.. you may need the angle grinder and a welder..
Author:  simon k [ Mon Sep 18, 2006 9:28 pm ]
Post subject:  Re: Fitment of 850 doors to a windup door-ed Morris
willy wrote:
I have a Matic that (of course) has sliding window doors
of course it didn't have sliding window doors, it had windup windows :P
and they're directly interchangable
Author:  willy [ Mon Sep 18, 2006 9:30 pm ]
Oops you know what I meant anyway!!! :lol:
Ah awesome.
Why did 850s use different catches?
Author:  graham in aus [ Mon Sep 18, 2006 9:32 pm ]
willy, I think you will find you need to swap the D shaped plastic things from the doors of the 850 onto the body of the matic or something, should be pretty easy but....
Simon, love the avater...... nice pair of eyes!! phwoooaar :P
Author:  simon k [ Mon Sep 18, 2006 9:40 pm ]
yeah.. I like it - got TME today Graham, very nice... but it the pictures don't really give the full effect of walking through your garage door :shock:
Different catches to what willy? the catches & striker plates look the same to me, from windups to sliders - the production cost of the 850 door is obviously much less
Author:  willy [ Mon Sep 18, 2006 9:43 pm ]
One seems narrower or something?
I dont have each to compare, but I do know that they have a different screw pattern.. the 850 holes are pretty much vertical (or horizontal?) I cannot remember.
AHhhhhhh maybe I'll find some doors and try to fit them up, see if it works :lol:
Author:  hutto [ Mon Sep 18, 2006 9:44 pm ]
no.. there actually slightly different but i think they still screw to similar holes.. have a look on other doors when you get a chance.. not a 100% sure..
Author:  drmini in aust [ Mon Sep 18, 2006 10:53 pm ]
I think you will find the 850 doors used the UK plastic wedge thingy, not the Oz made one which is a bit different.
But I modded UK ones for my `matic doors so they are not a whole lot different.
Author:  1071 [ Tue Sep 19, 2006 11:29 am ]
I replaced the (Aus) windups on my (UK) Traveller with a set of (Aus) 850 doors... They bolt straight on.
The only difference I could detect was that the white nylon support and corresponding bracket had to be swapped over (on UK cars the bracket in one the body whereas Aus cars seem to have the nylon support there). Both items use the same screw holes and are interchangeable.
Cheers, Ian
Author:  mickmini [ Tue Sep 19, 2006 11:45 am ]
the seals are definitely different as well...you might find that seals to suit the later windy doors are too thick and make it hard to close if you just stick them straight on. 850 door seals were 2 pieces - 1 is the rubber seal, the other is the locking strip. later ones are 1 piece both seal and locking moulded together.
Author:  simon k [ Tue Sep 19, 2006 12:06 pm ]
pretty sure all the roundies had those 2 piece door rubbers - all of mine have had them...
Author:  graham in aus [ Tue Sep 19, 2006 12:20 pm ]
The Doc and 1071 described the plastic block thing much better than I did......
What they said!
I hadn't thought about the seals, yes the Aussie wind up ones are too thick, 850 ones are one piece, I just put some new ones on my 850, $89 I think from Tony at Minisport.
:P
