It is currently Sun Aug 03, 2025 6:49 am
PostPosted: Tue Sep 19, 2006 11:01 pm
hey, im looking for pics of sound systems in minis (including boot)
~sumanovic
PostPosted: Tue Sep 19, 2006 11:19 pm
Heaps in the audio forum.
Jonathan
PostPosted: Tue Sep 19, 2006 11:49 pm
cheers, i found some...
~sumanovic
PostPosted: Wed Sep 20, 2006 7:24 am
Here ya go. Ive got an RDS tape deck head unit, 12 band Electronic Graphic EQ, a 6 Disc Stacker, two 12in Subs, two four ch Amps, two 7 by 10's, two 6 by 9's, two 6in's and a steering wheel remote...... All Kenwood gear.
PostPosted: Wed Sep 20, 2006 10:18 am
Is that all :!: :shock:
How often do you tighten up all the screws and bolts that loosen with vibes........
That looks awesome.
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
PostPosted: Wed Sep 20, 2006 10:26 am
Hanra.... how did you mount those 12's in the boot?
did you cut holes in the metal behind the back seat and bolt them directly to the metal?
1975 Hairy Lime/White Clubby
PostPosted: Wed Sep 20, 2006 12:45 pm
damn!!!!!!!!! thats crazy setup man! i thought my stereo setup in my mini was crazy but damn thats nuts! how much power u runnin in that? got two batteries? i have a 200w Pioneer mp3 tuner, 2x 6.5" Response speakers, 300wrms 15" Response Subwoofer, Response Amp and Response 1 farad capacitor and that is extremely loud as it is! :D
Image Image
Everything else is hidden hehe :shock:
1992 Toyota Starlet GT EP82
PostPosted: Wed Sep 20, 2006 12:53 pm
The rear metal section behind the back was cut away to allow clearance for the subs, another section of sheetmetal was then fixed in place to stregthen everything, this was also cut to allow clearance of the subs. This basically is a piece of 2mm sheetmetal with 2 holes cut in it, I really tried to make sure no structual integrity was lost.
The subs are mounted to a baffle board made of 12mm MDF, the rest of the boot is also boxed with 12mm MDF, the spare tyre is underneath everything......Its a mission to get it out.....
I kinda tried to make the volume of the boot the same as wat is required by the 2 subs. I think its a little bit larger, but anyways it still sounds ok.
The amps are only 100w per ch. But thats a peak figure, not true RMS. Its loud enough, but as with anything could always be louder. I wouldnt mind getting some more amps with a bit more grunt.
Nah only got the 1 battery, plus i got a decent alternator.
PostPosted: Wed Sep 20, 2006 4:00 pm
Boot Setup
1 Farad Soundstream Cap
1 Rockfordfosgate 1071wrms monoblock amp for the 2x 15" Rockford Subs
1 500wrms Boston mono block amp for the 2 Rockford Fosgate 6x9's in the rear parcel shelf
1 600watt max Rockford Fosgate amp for the front speakers
And powered by a Optima yellow top battery and bigger alternator
Subs in place of backseat
Front Speakers.. Only 4" but that is what size hole it was...
Now all this was in the clubman which then got resprayed, then written off so if any one wants the sound setup feel free to ask... pm me obviously i dont want to hijack the thread any further more :lol:
Life's a garden.... Dig It!
