ok ok ... I give UP!!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=22760
Author:  Brown Clubman [ Wed Sep 20, 2006 5:40 pm ]
Post subject:  ok ok ... I give UP!!
What's the trick to fitting bumpers and correctly aligning the bolts in the holes? Is there a sequence ..... do I have to hold my tounge right ??
Any tips/tricks would be appreciated.
BC.
Author:  Curly [ Wed Sep 20, 2006 5:44 pm ]
I always start in the middle and work outwards. Don't tighten them until you have them all in place and lined up.
Author:  Smokie [ Wed Sep 20, 2006 6:52 pm ]
BC, it has to be in your left ear otherwise the bolts wont fit..
I had to fit both mine after the painting was done and found the back one was a little bit more fiddly than the front but did it all by myself, so it can't be that hard...
Author:  aussie [ Wed Sep 20, 2006 7:19 pm ]
ive never had any troubles.. just worked from the inside out. maybe your bumper is crooked?
Author:  Smokie [ Wed Sep 20, 2006 7:24 pm ]
Hey Curly, I know that place you have in your avitar.. Got your team all ready for the 6 hour at the Island???
Author:  Mick [ Wed Sep 20, 2006 7:25 pm ]
Sprinkle water on your head and turn around three times. Also good for getting the universals on and for speedo cables in the car.
Author:  Curly [ Wed Sep 20, 2006 7:36 pm ]
Yep Jack, exiting the keyhole at Morwell Hillclimb - It'll be a sad day when the circuit succumbs to the coal dredges, but the plans for the new track look great.
Team Wild Dog are keen and raring to go, a shame there's no BMCs in the group - the Island doesn't really suit small capacity cars.
Author:  jbeenz [ Wed Sep 20, 2006 7:44 pm ]
my bmpers go on fine...one bolt on the front one, two on the back...the rest are broken :roll:
Author:  LS1380 [ Wed Sep 20, 2006 8:06 pm ]
The LS has recently come back from the Painters.
Had to fiddle around to correctly line the front bumper-do it by "feel" and no looking.
Tip=Put some rag on the ends where it wraps around the body work-this will save your new paint as you line -up the bumper.
Author:  Brown Clubman [ Wed Sep 20, 2006 8:53 pm ]
:shock: WASH YOUR MOUTH OUT WITH SOAP !!!!
I suppose it's possible :wink:
It could also be that the rail that it sits on is slightly bent ??
Author:  Brown Clubman [ Wed Sep 20, 2006 8:55 pm ]
:lol: :lol:
Speedo cables = sore knuckles!!! :x :x :x ARRRRGGGGHHH!!!
Author:  nullarbor express [ Wed Sep 20, 2006 9:07 pm ]
well done to you for having it at that stage anyway!
I think i am falling behind a bit!
Cheers, Bryan
Author:  9YaTaH [ Wed Sep 20, 2006 10:11 pm ]
Post subject:  Re: ok ok ... I give UP!!
BC.
Just remember...they aren't gunna break easy....so twist and bend all you need to get each captive bolt to pop into its hole :idea:
Author:  slinkey inc [ Wed Sep 20, 2006 10:29 pm ]
:lol: I had this problem you see I bought bumpers, went to go put em on and thought where the hell do they mount...turned out that I didn't know much about minis and bought one where the bumper mounts were groud off so i bolted litte L brackets on and it all fits now...back is slightly crooked tho, only noticed that the other day whe my dad pointed it out!
