It is currently Thu Aug 14, 2025 5:04 am
 Post subject: Guess who but don't Sue
PostPosted: Sun Sep 17, 2006 8:11 pm
Who has broken another accelerator cable agian. (Around 5 now)
Yep a IT pro
I don't know any one who has broke know more :shock:
:lol:
PostPosted: Sun Sep 17, 2006 9:02 pm
If the cheap three dollar ones are snapping, splash out six bucks and get one of those real special teflon lined ones from a bike shop.
Go on, your mini deserves it!
 Post subject: Ouch!!
PostPosted: Sun Sep 17, 2006 10:16 pm
Heavier return spring on the pedal :idea: :?:
Probly broke cause it`s not been set up proply
simple
most times it`s simply cause Tom Dick or Harry set it up without realising how to do it the "RIGHT" way,,,dam even a push bike cable lasts if it`s sert up the "RIGHT" way & i don`t even use push bike cables "EVER"!!@!!!!!!!
so there :-)
sorry, im drinking burbon :-)
PostPosted: Sun Sep 17, 2006 10:17 pm
& ytou know what i`m like when i drink burbon :-)
 Post subject: address....
PostPosted: Sun Sep 17, 2006 10:19 pm
Party!!...wheres the party!! :lol:
PostPosted: Sun Sep 17, 2006 10:38 pm
i know josh comes pretty close with snapping throttle cables; emmeline replaced one, chris replaced one, and i replaced one for him today
did it snap where you tighten the nut around it?
Inconspicuously Conspicuous
PostPosted: Sun Sep 17, 2006 11:30 pm
so there :-)
I can't see any difference in the cables, except one cost thirty and the other costs six...
The coopers has lasted ten years since I last changed it. :wink:
PostPosted: Sun Sep 17, 2006 11:37 pm
The vehicle in question has a Dellorto and a problem with the cable pull angle, it's not good... :cry:
Linkage needs work.....
PostPosted: Sun Sep 17, 2006 11:49 pm
i've never broken an accelerator cable, but how do you make it less jerky on and off?
PostPosted: Mon Sep 18, 2006 12:12 am
Those spring you get outta grab kits aren't so very good.
I like the springs used on twin SUs, they're kinda soft and progressive.
but there must be common ones out there which are ok, maybe from another car? What do other people use?
PostPosted: Mon Sep 18, 2006 8:49 am
Joshie time to look for a new linkage :shock:
Lillee - 1969 Morris Mini K
PostPosted: Mon Sep 18, 2006 8:51 am
Hey it's the same as yours and mine, but the ball ended rod is too long... :lol:
PostPosted: Mon Sep 18, 2006 8:53 am
They are talking about me :lol:
It's the linkage angle and the sweep is so long that the nut bends the wire on full throttle..eventually fatigues it and breaks.
PostPosted: Mon Sep 18, 2006 9:04 am
you can buy these adapter things from a roles or jag/bentley..i dont know, but its a right angled elbow piece so you can conect the speedo cable and instead of it hitting your air filter it goes off on a angle downwards... i've broken 2 cables before aswell.
Users browsing this forum: No registered users and 284 guests
