Brake Rotors. https://www.ausmini.com/forums/viewtopic.php?f=2&t=22815 |
Author: | leyland brother [ Fri Sep 22, 2006 6:42 pm ] |
Post subject: | Brake Rotors. |
I just got my new rotors for the LS today from eBay and i noticed that there are no studs in them. Should i get new ones and screw them in or try to get out the old ones??? I think i may need on of those 1/2" sockets with the rollers inside, which i don't have. |
Author: | Mick [ Fri Sep 22, 2006 6:57 pm ] |
Nah, you can use the old ones if you need to, you need to tap, tap, tap them out with a soft mallett. They are simply held in by a press grip on splines, just tap them backwards through the disc flange. If you get new ones, the disc studs are slightly longer than the standard drum type. ![]() |
Author: | GT [ Fri Sep 22, 2006 7:43 pm ] |
hmmmm...I have heard of studs developing hairline cracks from being removed and replaced. Personally, with new rotors I would DEFINITELY buy new studs. Up to you though....... |
Author: | drmini in aust [ Fri Sep 22, 2006 8:20 pm ] |
Don't the LS brakes have the studs in the drive flanges- not the rotors like S did? ![]() I have Josh's new ones here..... the 8.4" drive flanges have the studs. |
Author: | Morris 1100 [ Fri Sep 22, 2006 8:42 pm ] |
The doc is right, they have the studs in the drive flange and the flange bolts to the disc. |
Author: | Mick [ Fri Sep 22, 2006 9:16 pm ] |
aaaaahhhhh....so now I know, are they still held in the same way? I've always re-used them with no ill affects, although I have broken one or two before. When I pull them back through, I don't whap 'em back in, I pull them through using the wheel nut nice and gentle, maybe this is where hairline cracks develop if you're not kind to them. |
Author: | leyland brother [ Fri Sep 22, 2006 9:34 pm ] |
drmini in aust wrote: Don't the LS brakes have the studs in the drive flanges- not the rotors like S did?
![]() I have Josh's new ones here..... the 8.4" drive flanges have the studs. These have threads tapped in them as per pic.... ![]() If the studs are attached to the drive flange then have i bought the wrong rotors? |
Author: | simon k [ Fri Sep 22, 2006 9:41 pm ] |
no, you've got the right rotors, those threads are where the drive flange bolts on.... ![]() |
Author: | leyland brother [ Sat Sep 23, 2006 7:19 pm ] |
Job Done! Was a bit of a sh!t getting the hub nut off though... |
