Gearbox numbers https://www.ausmini.com/forums/viewtopic.php?f=2&t=22845 |
Page 1 of 2 |
Author: | Panthersteve [ Sat Sep 23, 2006 6:20 pm ] |
Post subject: | Gearbox numbers |
Hi all I am hoping someone here can clear the numbering of gearboxes up for me. I have a Cooper S gearbox, casing number is 22G1128, what makes this a Cooper S box ![]() ![]() Similarly, I need a gearbox for my '64 Cooper, I believe this should be a 22G68 casing number but I've heard of this number coming from a deluxe and Morris 1100 as well. Please help me understand. Cheers Steve |
Author: | Morris 1100 [ Sat Sep 23, 2006 7:03 pm ] |
The casting number is just that, a number to identify the casting. A few different cars may use the same casting. What counts is having the correct internals inside the correct gearbox case. |
Author: | drmini in aust [ Sat Sep 23, 2006 7:03 pm ] |
Post subject: | Re: Gearbox numbers |
Panthersteve wrote: Hi all
I am hoping someone here can clear the numbering of gearboxes up for me. I have a Cooper S gearbox, casing number is 22G1128, what makes this a Cooper S box ![]() ![]() Similarly, I need a gearbox for my '64 Cooper, I believe this should be a 22G68 casing number but I've heard of this number coming from a deluxe and Morris 1100 as well. Please help me understand. Cheers Steve 22G1128 box is used on Mini-K, Mk2 Cooper S, Clubman GT and Clubby 1100 up to 1973 approx. What makes a Cooper S/GT box is they have Hardy Spicer U/Js, the others had rubber couplings. Also the 1st motion shaft and cluster gear (laygear) are different, so 1-2-3 gears are slightly higher gearing. 22G68 box casing was used on many things including 997 & 998 Cooper, and the Mini Deluxe. The Coopers had different gear ratios. |
Author: | Panthersteve [ Sat Sep 23, 2006 7:07 pm ] |
Hi Ok, that all makes sense. Now for the next question. If I got a 22G68 casing, can I then put the right internals in it to make a Cooper 998 box ![]() ![]() Cheers Steve |
Author: | drmini in aust [ Sat Sep 23, 2006 7:47 pm ] |
It gets messy with that 3 synchro case, if it's got A type gears now you need the full Cooper gearset and mainshaft, to convert it to B type Cooper gears. Most of this stuff is now NLA (no longer available). ![]() If it has B type gears already (with needle rollers inside 2nd & 3rd gears) you will need the Cooper 1st motion shaft, 3rd gear and a 22G1100 cluster gear. Personally, unless running in Nb racing I'd fit a 4 synchro box- gears etc are much easier to get. All it takes to convert a Mini-K box to S box ratios is a 22G1371 1st motion shaft, and a 22G1040 laygear. ![]() |
Author: | gafmo [ Sun Sep 24, 2006 7:39 pm ] |
not sure what your intentions are but I / will be staying with the 22G1128 for my Cooper S Motor |
Author: | Panthersteve [ Thu Nov 09, 2006 10:00 pm ] |
"If it has B type gears already (with needle rollers inside 2nd & 3rd gears) you will need the Cooper 1st motion shaft, 3rd gear and a 22G1100 cluster gear". Hi I am still thinking of getting a deluxe gearbox with the 22G68 case number and "making" it into a Cooper by doing the above. What I would like to know now is if the bits mentioned above would be available ![]() Cheers Steve |
Author: | Lillee [ Thu Nov 09, 2006 10:10 pm ] |
I say don't bother with 3 synchro always crunch in first unless you double clutch into 1st. I use first often when say aproaching a round about so it would effectly cut down the usage of your gearbox by 25% (1 gear out of 4). If you are going to the trouble of building a "cooper" ratio box, why not just get your hands on a 4 synchro 12g1128 box and buy the laygear and 1st motion to conver it into a Mk2 Cooper S box? This is exactly what I did and (although I have not yet driven it) I like the results so far. Also the diff ratio may be shorter (like 3.67) on a 3 synchro box and may not match your current speedo which means it may read wrong. I think a well tuned mini runs well on 3.44 (S Diff) as it has something to pull against and it is a good compromise for cruising at highway speeds vs taking off.... |
Author: | drmini in aust [ Thu Nov 09, 2006 10:23 pm ] |
Not only are 3 synchro box parts much harder to get now, the box is not as strong. Fastest moving gearbox item back in the `60s was new 2nd gears, and cluster gears.. I know, my bro sold em, and I bought em!! And I also had a brand new 998 Cooper 1st gear go BANG! the first time I nailed it... ![]() Mini K/Clubby 1100 remote box is well worth it, they are cheap as chips now. Who would want a non-synchro 1st gear these days. ![]() To make it S ratios, only 2 gears need to be changed. And yes you can still get em. |
Author: | Panthersteve [ Thu Nov 09, 2006 10:29 pm ] |
I know it's not everyones cup of tea but I want to restore this Cooper to original, so really want the correct gearbox in it. I take it from your comments that the bits I would need for the 22G68 box would be very hard to find ![]() Steve |
Author: | Wombat [ Fri Nov 10, 2006 6:48 am ] |
drmini in aust wrote: Not only are 3 synchro box parts much harder to get now, the box is not as strong.
Doc do you mean the case or just the internals? Would the 4 speed synchro guts fit into a 3 speed box? As I have mentioned elsewhere I would like to put the Magic Wand gear lever back for the full MKI "look" Now I can try to change the diff housing over (if it lines up) but as I'll be pulling the 4 speed apart a bit to u/haul it would it be another approach to drop it into the 3 speed box? |
Author: | Lillee [ Fri Nov 10, 2006 7:41 am ] |
Panthersteve wrote: I know it's not everyones cup of tea but I want to restore this Cooper to original, so really want the correct gearbox in it.
I take it from your comments that the bits I would need for the 22G68 box would be very hard to find ![]() Steve OK I was just about to say that that would be the ONLY reason you would want a Cooper 3 synchro box. In which case go for it... Yes you can convert any 3 synchro to a cooper box by changing gears but not sure if they are available anymore. It wouls be easier to find a cooper box, I know where there are at least 10 of them ![]() ![]() |
Author: | graham in aus [ Fri Nov 10, 2006 9:06 am ] |
Chong; If you're not talking about me I want to know where please!! ![]() ![]() ![]() ![]() Graham |
Author: | Lillee [ Fri Nov 10, 2006 9:25 am ] |
Graham I AM talking about you you goose! ![]() ![]() ![]() When i said 10 I didn't specify if they were inside of cars or not ![]() |
Author: | graham in aus [ Fri Nov 10, 2006 9:39 am ] |
Oh! OK! Good! I thought so! I probably have about 8, but most pretty poor condition, as has been said, parts are nigh impossible to find, I have lost track of how many boxes I have counted the teeth on trying to find the holy grail! A good compromise would be a 3 sync straight cut gearset in a 22G68 box, I believe these are still being made? the ratios are good and the gears aren't too noisy, most of the whine comes from straight cut drop gears. The gearboxes were really the weak point of 997's not too sure on 998's but I would guess not much better. Depends on how close to original you want to be! Would you put back in a coil spring clutch? ![]() |
