front suspension cones...
https://www.ausmini.com/forums/viewtopic.php?f=2&t=22891
Author:  nullarbor express [ Sun Sep 24, 2006 10:48 pm ]
Post subject:  front suspension cones...
Hi all, was wondering if anyone can tell me if there is a way to remove the alloy cone from the rubber section of the front suspension cones on an early mini. I have already taken them out of the subframe and did this without the compression tool (was a pain in the #%@* but got it done).
So anyway now i am rebuilding the front suspension and all that but cannot separate the alloy from the rubber... have got a set of hi-lows to fit.
Ps. i don't have the tool to compress the rubber...
All hints and clues welcome,
Cheers, Bryan
Author:  drmini in aust [ Mon Sep 25, 2006 7:23 am ]
spray around the top of trumpet with WD40, leave a while...
Then put the trumpet in a vice, go round it with a cold chisel and a BFH....
If all else fails, cut it off next to the cone, then split & remove the remains with the chisel, or dremel it. :wink:
Author:  nullarbor express [ Mon Sep 25, 2006 8:41 am ]
Sounds like a plan! Thanks doc.
Ps. why didnt i think of that? :roll:
Cheers Bryan
