It is currently Mon Jul 21, 2025 3:52 pm
PostPosted: Tue Sep 19, 2006 7:28 pm
hey all,
i brought a box of su's and just woundering what a few of the things are....
what is the hose for???
whats this???
and because these are joined does that make them special :roll:
thanks for all your help
james
'75 windowless van
~LOLA~
PostPosted: Tue Sep 19, 2006 7:32 pm
monkey wrote:
whats this???
that young james, is a toothbrush.
Inconspicuously Conspicuous
PostPosted: Tue Sep 19, 2006 7:34 pm
the only good thing i see is that you have extra parts in case you need some for your existing carby on your car. dunno why that manifold is welded up again
i once needed to rebuild a carby, i used parts from here and there.
i once needed a vaccuum nipple, i pulled it out from a spare :wink:
PostPosted: Tue Sep 19, 2006 7:35 pm
a toothbrush eyyy???
yerp young n dont no much bout cars :)
'75 windowless van
~LOLA~
PostPosted: Tue Sep 19, 2006 7:45 pm
yeh i was gonna keep em cause i was gonna switch back to su's because my solex was running really ruff but now that its been tuned propperlly i have no use for these...
so i will be selling but just wanna no what i'm selling first :wink:
'75 windowless van
~LOLA~
PostPosted: Tue Sep 19, 2006 8:17 pm
That manifold is worth nothing. Stocker.
PostPosted: Tue Sep 19, 2006 8:38 pm
I think someone was after one in the wanted section recently though , might be worth checking . The 1 1/2" manifold you have is a bit scarcer than the 1 1/4" and people are probably looking for it .
PostPosted: Tue Sep 26, 2006 11:35 am
Don't you mean bought?
PostPosted: Tue Sep 26, 2006 11:43 am
That hose goes into the rocker cover. It is Mini K spec, and possibly Clubman 1100 spec (up until around 75).
That is 1/2 an HS4 1.5" carb.
That prolly only good enough to cut the inlet bit off to use an HS4 with extractors.
