It is currently Tue Aug 05, 2025 11:18 pm
 Post subject: Wouldn't you know it!
PostPosted: Wed Sep 27, 2006 4:47 pm
Went and bought a mech temp gauge today due to short in elec system playing with the original gauge. Went to screw plug into the block screw was same size thought to myself great! Something finally working out right. :shock: Wouldn't you know it screw to short temp gauge moves in out out of the housing with the screw all the way in! Cracked the sads, :cry: swore a bit then decided to install the reconditioned heater core into the heater knowing how hard it is normally to get them out. At least that worked. Beat my old record and didi the heater in and out in 30 mins not 3hrs like last time. Just needed a vent feeling better now! Thanks. :D
PostPosted: Wed Sep 27, 2006 4:54 pm
I've had this problem as well, fit it up and give it a try with water in the system. I purchased one of those cheap gauge sets for the clubby and found the same thing, but as they have been fitted to minis for years I persevered and filled her up. Sure enough, no leak and all is fine and dandy.
Give it a try. I fit doesn't work I suppose you can put some copper packing in between the sender and the bushing.
PostPosted: Wed Sep 27, 2006 4:58 pm
Thanks mick. Shall give it a go in the morning. :D
PostPosted: Thu Sep 28, 2006 11:13 am
went one better today. Went back to pistons auto and saw lindsay who made me an adapter for the gauge to stop the leaks. About to attempt install now. Here goes nothing!
PostPosted: Thu Sep 28, 2006 12:35 pm
Even my Autometer temp gauge does the same thing, the sender screws into the head but moves in and out of its housing, obviously leaks a sh*t load of water. I had to get an adaptor for mine as well.
PostPosted: Fri Sep 29, 2006 9:31 am
All is good now. Just screwed sender into the new adapter and away we went. The temp sits up at about 160f and will slowly creep up to bout 170-180f in the traffic. I can now run the lights, ipod, heater etc without thinking the car is redlining it's heat level. Makes a huge improvement. Plus when it's cold i now have a heater to keep me warm on the way home at 12am! Woohoo. :D
PostPosted: Fri Sep 29, 2006 10:11 am
Prolly a forum for this but, can you describe how you use your Ipod? Has it a special head unit or something?
