It is currently Sat Aug 02, 2025 1:06 am
 Post subject: flat battery
PostPosted: Tue Oct 03, 2006 12:06 pm
so i hop in to drive to get rego and battery is flat and then i hook it up to my gf's car and its not chargin the battery how crap.
what am i doing wrong? + to +, - to -, car on, turn it over and "bla... bla.... blaaa... bl.... b... ........ ....peice of crap!"
so annoying
PostPosted: Tue Oct 03, 2006 12:35 pm
do you have GF's engine running?
check your earths, problem may not be the battery
PostPosted: Tue Oct 03, 2006 12:46 pm
K-Mart or SuperCrap jumper leads? A waste of $9.95 :P
(spend the money on a jug of beer & a packet of chips
- at least then you will feel satisfied when the car won't start) :idea:
Try putting the good battery in & then starting it.
PostPosted: Tue Oct 03, 2006 1:02 pm
if the battery is really flat you may need to wait a few minutes with her car running, then give it a crank. look at the reason why its flat - if its just because you have left it long then thats fair enough but if not your alternator is more than likely not doing its job
PostPosted: Tue Oct 03, 2006 1:09 pm
it was flat cause i left it a while, but yeh, jumper leads ended up snapping from the handles when i tried to put them on and pull them off the 2nd time. looks like i'll have to go buy sum new ones. thanks for help.
PostPosted: Tue Oct 03, 2006 1:13 pm
If the jumper leads came apart at the handles , strip the end of the wire back and use the clamp/handle/oversized aligator clips of the jumper lead to hold the bare cable onto the batter to start it and make sure it runs . Once it's going and you've gone for rego , throw the old jumper leads out and get a new set .
PostPosted: Tue Oct 03, 2006 2:09 pm
by theory you shouldnt jump any car with jumper cable on -ve to -ve it should be -ve source to earth on the flat battery car.
But still I dont follow this :lol: just takes a little longer.
Hope you got you car started....
