need help quick, engine removal https://www.ausmini.com/forums/viewtopic.php?f=2&t=23397 |
Page 1 of 3 |
Author: | buztoy [ Sun Oct 08, 2006 7:05 pm ] |
forgot to mention this is at the back of the tranny |
Author: | DOZ [ Sun Oct 08, 2006 7:07 pm ] |
Get a pin punch and drift them out, if you don't have a pin punch then a concrete nail with the tip ground flat will work (the right diameter of course). They are spring pins and I think they are stepped so will only go one way, if you can't remove one, try the other one. regards Daniel |
Author: | aussie [ Sun Oct 08, 2006 7:09 pm ] |
i remember this bloody pin. you need something exactly the same size as the pin and punch it through. we ended up just cutting it off ![]() |
Author: | 13secmini [ Sun Oct 08, 2006 7:11 pm ] |
An electric drill chuck key is what i used years ago, give it a good hit. |
Author: | drmini in aust [ Sun Oct 08, 2006 7:23 pm ] |
Put it in Reverse, then use a 3/16" pin punch to drive the front pin out. If you don't own a PROPER pin punch, go buy one, or a set- before you slip with the BFH and hurt yourself... ![]() ![]() |
Author: | buztoy [ Sun Oct 08, 2006 7:51 pm ] |
sorry guys never heard of a pin punch, im gonna drill the thing, |
Author: | Morris 1100 [ Sun Oct 08, 2006 7:55 pm ] |
buztoy wrote: sorry guys never heard of a pin punch, im gonna drill the thing, Good thinking, it should be a lot easier to remove with a broken drill in it. ![]() |
Author: | Mini Mad [ Sun Oct 08, 2006 8:36 pm ] |
^^^ ![]() It's a rolled pin..you use a pin punch to drive it out...you will need it to put back once you put the engine back in so it's worth saving ![]() |
Author: | Lillee [ Sun Oct 08, 2006 8:45 pm ] |
Go to your nearest supercheap auto, say "Hi I'd like a pin punch set" and pay the person around $10... You will need it again to put the engine in with a new pin anyway... |
Author: | buztoy [ Sun Oct 08, 2006 10:53 pm ] |
yeah got him out, why cant i use 2 split pins |
Author: | Mini Mad [ Sun Oct 08, 2006 10:54 pm ] |
Cause your gear change will be even more sloppier than it already is... |
Author: | buztoy [ Sun Oct 08, 2006 10:58 pm ] |
great, my shifter is about as sloppy as a bulldog eating poridge, pin punch eh, can you buy new pins |
Author: | mad-mk1 [ Sun Oct 08, 2006 11:07 pm ] |
n its not alot of fun when the pin falls out and your stuck in 3rd!!! on the main st ![]() ![]() |
Author: | drmini in aust [ Mon Oct 09, 2006 7:27 am ] |
buztoy wrote: yeah got him out, why cant i use 2 split pins
Split pins are soft crap, even softer now made in China... ![]() And always undersized. The proper pins are a `roll' or `spring' pin, they are harder, and a tight fit so the linkage has less slack. Do it properly- these pins cost peanuts... ![]() |
Page 1 of 3 | All times are UTC + 10 hours |
