Tyre Pressures
https://www.ausmini.com/forums/viewtopic.php?f=2&t=235
Author:  PhildoD [ Mon Apr 05, 2004 6:21 pm ]
Post subject:  Tyre Pressures
Ok, I just pumped up the spare tyre in my car(yep, the 1974 Original with hubcap), and realised I had no idea how much pressure to fire into it.
So in conclusion, what's the recommended tyre pressure for a mini, and what are the pressures you run in your tyres?
Author:  poeee [ Mon Apr 05, 2004 6:33 pm ]
I wack 30psi in. Whether it's right, I dno.
Author:  998_Clubman [ Mon Apr 05, 2004 6:53 pm ]
i run about 36 psi in mine 165x10
Author:  drmini in aust [ Mon Apr 05, 2004 7:31 pm ]
Cooper S (first Mini with 145-10 radials) used 28F/26R.
I run 30F/28R on the road, on the track I pump 'em up to 36F/34R. Using Yokohama 165/70-10 A008s.
Author:  PhildoD [ Mon Apr 05, 2004 8:28 pm ]
Cheers fella's. Letting em fall to 20 definitely makes the steering sloppy. Much better above 25
Author:  poeee [ Mon Apr 05, 2004 8:35 pm ]
Specially the rears. Not good having your rear end think for itself!
