Length of a leyland mini van? https://www.ausmini.com/forums/viewtopic.php?f=2&t=2359 |
Author: | monkey [ Sat Oct 16, 2004 8:44 pm ] |
Post subject: | Length of a leyland mini van? |
does any one know how long is a '72 mini van? i cant find any specs on it ![]() cheers |
Author: | miniVan [ Sat Oct 16, 2004 9:06 pm ] |
well my bellnose 71 is exactly 3.3m.. 72 is a clubby.. shed be longer gotta be a big trailer |
Author: | WhoDat [ Sat Oct 16, 2004 10:39 pm ] |
From Haynes manual Van overall length = 3298mm overall width = 1410mm overall hieght = 1359mm weight = 621.5Kg wheelbase = 2134mm |
Author: | gafmo [ Sun Oct 17, 2004 8:09 am ] |
Marcia wheel base 2150mm long and 1400 Wide (depends on what wheels/tyres U have) with my crappy take measure |
Author: | miniVan [ Sun Oct 17, 2004 9:13 am ] |
so the clubby is slightly shorter?? that doesnt make any sense |
Author: | WhoDat [ Sun Oct 17, 2004 12:59 pm ] |
The vageries of 70's "precision" engineering! I understand that the clubbie is a "couple inches" longer in the nose. If your measuring up for a box trailer, then add 100mm at each end, side & top for clearance and you should be right. [you need some space for transit movement] Just a thought: If you intend drive on/off, leave enought clearance for the driver to extracate. Cheers Dat |
Author: | thommo09 [ Sun Oct 17, 2004 3:14 pm ] |
nah just leave the driver in there! or if it's a van....they can always just climb out the back doors ![]() |
Author: | tzi [ Sun Oct 17, 2004 4:29 pm ] |
van is 4in longer in the wheel base than a standard clubby which is a "couple" inches longer than a roundie ![]() |
Author: | monkey [ Sun Oct 17, 2004 5:14 pm ] |
Cheers every1, i might just hire a proper car trailer if i do buy the van ![]() |
