Ignition problems help!!!!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=23637
Author:  dr gonzo [ Fri Oct 13, 2006 5:57 pm ]
Post subject:  Ignition problems help!!!!
I am taking my morris 850 to get a new waterpump tommorow and went outside to start it(as I do afternoons) it started fine but then began to lose revs and then stopped. It the started again fine but same problem. Also when I push the accelrator pedal NOTHING no revs, just says running at the same low rev, I could actuallt press the whole pedal in and it still would stay the same. I haven't taken it for a run for a week and a half but I really need to know what this problem may be as I have to get it to the mechanics tomorrow. Please help guys and girls.
Author:  dr gonzo [ Fri Oct 13, 2006 10:52 pm ]
thanks all???
Author:  speedy [ Fri Oct 13, 2006 10:54 pm ]
Have you check its getting enough fuel?
Author:  dr gonzo [ Fri Oct 13, 2006 10:57 pm ]
might sound silly, but how would I check that?
Author:  drmini in aust [ Sat Oct 14, 2006 6:06 am ]
Can you hear the fuel pump tick at all when you turn the ignition on...
If not it may need a swift kick like mine used to. :lol:
Undo the lid of the float bowl, see it there's petrol in there.
While it's off, put a tin under it, then get someone to turn ignition on for a few secs. :wink:
Author:  Mike_Byron [ Sat Oct 14, 2006 10:10 am ]
Throttle cable loose and slipping ????? Or broken ?????
Does it rev if you turn the throttle bit on the carby itself.
