It is currently Fri Aug 08, 2025 3:23 am
 Post subject: Door Hanging
PostPosted: Sun Oct 15, 2006 8:03 pm
Resident Test Pilot
Anyone tell me how easy or hard it is to adjust the position of the drivers door as it sits a little proud and hangs down a bit. do the mounting hinges have elongated holes or can they be made so??
PostPosted: Sun Oct 15, 2006 8:04 pm
well if you loosen the hinges then there is quite alot of movement of the whole door, so then you can get it in the right position then tighten up the hinges again.
PostPosted: Sun Oct 15, 2006 8:13 pm
Resident Test Pilot
thought that would be the case, thanks
PostPosted: Sun Oct 15, 2006 8:17 pm
no probs mate..get someone to give you a hand though. you dont wanna be doin it by urself :lol:
