Hi Low install help https://www.ausmini.com/forums/viewtopic.php?f=2&t=23788 |
Author: | Harley [ Tue Oct 17, 2006 9:11 pm ] |
Post subject: | Hi Low install help |
I've been outside sctratchin my head for a while, perhaps you clever folk can help. ![]() My subframe parts are going together and I'm trying to my hi-lows in. I've put in a new (old) rubber cone to replace the old (older, crapper, flatter) cone, and want to know how to get it all together? Do I need a cone compressor? I've also greased up the knuckle joint and put the rubber seal thingy on the plastic cup, so a way of assembly allowing me not to pull them apart again would be great! Thanks. ![]() |
Author: | Shard [ Tue Oct 17, 2006 10:07 pm ] |
we talking front or rear? I haven't fitted hilos yet but will be in the next month or so, from what I understand you adjust the hilo so it's retracted enough to just slip in and then start adjusting them out till they reach the desired height? Shard |
Author: | Harley [ Tue Oct 17, 2006 10:12 pm ] |
I'm doing the front. What you mentioned would work if I used the sagged cones that came out, but with newer cones in there's little room to work with. Can a bolt with washers sustitute for a cone compressor? (subframe isn't in car) |
Author: | Shard [ Tue Oct 17, 2006 10:14 pm ] |
Yeah if you can get it tight enough. If it's close enough to fit you could try gently tapping it in. Shard |
Author: | DTrain [ Tue Oct 17, 2006 10:19 pm ] |
i just did mine yesterday with new cones/hi-los/knuckles/cups and a cone compressor. i can tell you i needed an extention bar to get enough leverage to compress the cones - and that was with the hi-los fully screwed in (at the lowest setting). ill adjust them after the engine is on and they have settled give the bolt a go as if your putting in old ones it might not be as hard to compress |
Author: | Harley [ Tue Oct 17, 2006 10:26 pm ] |
Thats's what Im lookinfor, thanks guys. ![]() Okay, I'll need tofind a big ass bolt then. ![]() |
Author: | monrel [ Tue Oct 17, 2006 10:32 pm ] |
Post subject: | no need for cone compressor |
I did mine a while ago without a compressor, check it out here... http://www.ausmini.com/forums/viewtopic ... ht=#203495 |
Author: | Harley [ Tue Oct 17, 2006 10:42 pm ] |
Monrel, you're a genuis! Thanks for that. ![]() That should be a 'How to'. (Hint hint mods) ![]() |
Author: | Shard [ Tue Oct 17, 2006 10:46 pm ] |
I'm guessing that how to doesn't work if you're trying to do it subs in the car still? ![]() Shard |
Author: | Harley [ Tue Oct 17, 2006 10:49 pm ] |
Still would work, you just use a bolt 8 inches long instead of 4. ![]() |
