door and window rubbers https://www.ausmini.com/forums/viewtopic.php?f=2&t=23836 |
Author: | mini-dunger [ Thu Oct 19, 2006 8:20 am ] |
Post subject: | door and window rubbers |
hi guys How thick are the door and rear window rubbers on a clubman? Would a rubber strip similar in thickness to a normal commodore boot/door rubber be good idea or will they be to thick and cause the doors not to close properly?. The reason I ask is because I have to go to clark rubber and I have learnt from here(ausmini) that they sell an off the roll boot seal. I was hopeing to use this stuff for all my door and window sealing needs. Thank yall |
Author: | GT [ Thu Oct 19, 2006 8:58 am ] |
YOu really need a sample to match the stuff on the roll. It comes in MANY shapes and sizes. Too thick will make your doors impossible to close. It could even bend them! ![]() |
Author: | minimalist_1 [ Thu Oct 19, 2006 12:29 pm ] |
Post subject: | clark rubber door and boot rubbers |
I have installed door and boot rubbers from clark rubber, works great. Just take a sample of the standard ones and compare. The boot rubber is the best. I installed one on the body rather than the boot itself and pulled the old one off the boot, also pullerd off the clips that retain the old one. They will probably snap anyhow. |
