It is currently Sat Jul 19, 2025 11:22 pm
 Post subject: Cost of a rebuild?
PostPosted: Thu Oct 21, 2004 4:55 pm
Does $1500 (starting rate) sound rite for an 1100 engine rebuild? :?
'75 windowless van
~LOLA~
 Post subject: Re: Cost of a rebuild?
PostPosted: Thu Oct 21, 2004 6:32 pm
Weeeeell, I think the parts alone would be around $750ish then you throw in labour....it sounds reasonable to me....just be prepared for the "oh we found this and that worn out when we stripped her down and here's a bill for an extra 500!"
Don't know if they all do it on purpose just to suck you in but it seems quite common to "bid low and watch it grow!" :roll: :shock:
PostPosted: Thu Oct 21, 2004 7:41 pm
aint that the truth :roll:
www.crazybitchracing.com
PostPosted: Fri Oct 22, 2004 7:42 am
try and get a shop that will give you a fixed bill i found none of the sydney would aprt from the one in Thornleigh and they did a brilliant job, guy use to work for BMC the one that does the engine's well that was 6 years ago, sorry been a while since Aus visit to mini Shops but try them
PostPosted: Fri Oct 22, 2004 8:29 am
i think it sounds reasonable for a full engine
rebuild. who is doing it for you?? ive got my engine
(1100s) at the moment being rebuilt by Russell engineering.
hopefully i will have it done soon - don't know what
the final price will be yet.....
PostPosted: Fri Oct 22, 2004 12:44 pm
$1500?? Thats what my cam grind and cylinder head cost to be ported by Russel Engineering. How serious of a rebuild are you planning??
PostPosted: Fri Oct 22, 2004 12:51 pm
$1500? my cam grind is only $80!!! my head reco was $200!!
but then again your car is being featured in
hot 4's so i guess you have done a bit of serious
work to it, mine is only mild stuff. how have you found
the work through Russell Engineering. so far i am
really happy with it all. im keeping my fingers
crossed that he isn't going to hit me with a big bill at the
end.....
PostPosted: Fri Oct 22, 2004 3:58 pm
The cylinder head was shaved, heavily ported/polished and had the combustion chambers cc'd slightly, also had hardened valve seats fitted to run it on unleaded. New valve springs and valve stem seals were also fitted. I couldnt tell you the exact specs on the cam, was done to suit the head. The quality of the workmanship was very good, I havnt heard a bad comment about his work. The only down side was that it did take quite a few months to get it all done. Good things come to those who wait, I guess.
PostPosted: Fri Oct 22, 2004 7:04 pm
Deffinently nothing serious just a "standard" rebuild" the quote was from a guy on the central coast called - AMC automotive - he imports mostly '89 mayfairs, and other things.
'75 windowless van
~LOLA~
PostPosted: Fri Oct 22, 2004 9:05 pm
GR I have never had a problem with at all...I Have just fitted a RE13 into day into Morris (Sue's) 1100 +60...can't wait to start her up and see how she goes...And I'll do a New Post (RE13 Cam). I'm lucky he is just down the road....But...Call first.
My 2 bob's worth on G Russell
PostPosted: Fri Oct 22, 2004 9:35 pm
Been getting cams ground and cylinder heads done by Graham Russell for nearly 10 years, excellent work. Even got to meet David Vizard at his shop in 1995! Steve
PostPosted: Fri Oct 22, 2004 10:03 pm
Yep, GR does my stuff too, Mini Mad's 295 head and lightened flywheel are down there right now.
It's going on another 1152, just like Gafmo's, only faster.... should run next week. 8) :P :lol:
Users browsing this forum: Majestic-12 [Bot] and 90 guests
