pot joints
https://www.ausmini.com/forums/viewtopic.php?f=2&t=24288
Author:  dale 62 [ Tue Oct 31, 2006 3:52 pm ]
Post subject:  pot joints
hey i was just wondering if anyone could tell me what i would need to do to change my universal joints to pot joints??
Author:  doogie [ Tue Oct 31, 2006 4:01 pm ]
You need different driveshafts, the actual pot joint, the ball bearings & you need to change over the diff out put shafts, a easy job if you know what you are doing.
Doogie
Author:  dale 62 [ Tue Oct 31, 2006 4:07 pm ]
thanks is this what you are talking about? http://minispares.com/Product.aspx?pid=34200 is that all i would need?
Author:  doogie [ Tue Oct 31, 2006 4:21 pm ]
That is just the actual pot joint, the tapered type end clips into the output shaft on the diff, all 3 types on a mini are different, you also need the right driveshaft, this has a cage the holds ball bearings that then slide into the pot joint itself. Any reason why you are wanting to change to pot joints?
Doogie
Author:  dale 62 [ Tue Oct 31, 2006 4:34 pm ]
i was going to get larger brakes http://minispares.com/Product.aspx?pid=34525 and i got told i would need pot joints?
Author:  doogie [ Tue Oct 31, 2006 4:38 pm ]
Thats not true, if you are going to update your brakes you can re use the current driveshaft you have, you simply knock the old CV joint off the driveshaft & put the driveshaft into the new CV on your new disc brakes im assuming, it a relativley easy job.
Doogie
Author:  dale 62 [ Tue Oct 31, 2006 4:40 pm ]
thanks for the info appreciated!
Author:  gafmo [ Tue Oct 31, 2006 7:21 pm ]
You have to Love Ausmini :wink:
