It is currently Sun Aug 03, 2025 2:49 pm
 Post subject: Fuel leak
PostPosted: Thu Nov 02, 2006 1:34 pm
Gday, I have an ongoing problem with my fuel pump. It always seems to be leaking at the hose going into the pump no matter how tight i do up the hose clamp. The pump in question is a facet solid state one. I tried a different size hose to the one on it before but it still leaks (Went from a smaller hose to a bigger one).
Gracias Amigos.
Howard: "You don't need a pen to be a writer Vince"
Vince: "I think you do"
PostPosted: Thu Nov 02, 2006 1:52 pm
is it the hose that's leaking or the little plastic cap that attaches to it...
i had the same problem a little while ago got new cap.... no more leak..
Users browsing this forum: Bing [Bot], drmini in aust and 102 guests
