It is currently Tue Jul 29, 2025 1:35 am
 Post subject: Difficult to select 1st
PostPosted: Thu Nov 02, 2006 12:22 pm
As the heading says... Having diffuculty selecting 1st gear (only when statonary).
When rolling forward slowly it goes in ok, which leads me to believe it could need a clutch adjustment, not a syncro problem.
Any thoughts or advice.
Thanks.
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
PostPosted: Thu Nov 02, 2006 12:34 pm
Try pumping the clutch rapidly, then selecting first.
PostPosted: Thu Nov 02, 2006 12:43 pm
me too santo!
mines a new box, so i am assuming its the linkage under the gear lever
somethign about a rod with an eye hole in it, that the gear lever goes into.
i (and quite a few others) pull it down towards 2 first, and then back up to 1
kinda helps
Inconspicuously Conspicuous
PostPosted: Thu Nov 02, 2006 12:53 pm
It's a common rod change problem when the linkages wear out. As Duc says it is wear in the lever in many places, the biggest offender is this part here:
http://cgi.ebay.com.au/Mini-Rod-Change- ... dZViewItem
PostPosted: Thu Nov 02, 2006 12:57 pm
teh admin God
teh admin God
Me too Santo!
And there is only a very small range of very slow crawling that lets me get it in 1st.
I suppose its no real problem,
Just a little annoying.
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Thu Nov 02, 2006 12:58 pm
kinda helps
Thats what i used to do. 2-1-2-1-2-1....1 Done!
Ah, the joys of owning a mini... :roll:
PostPosted: Thu Nov 02, 2006 1:11 pm
Stuwey wrote:
kinda helps
Yeah... Joy!
What makes it worse is i've installed a KAD quickshift and the closer ratio makes it harder to engage... (BUT quicker to change :!: :wink: )
Lillee... Does that steel sleeve connect the rod to the selector shaft?
Santo
"The Lone Ranger"
PostPosted: Fri Nov 03, 2006 8:32 am
Santo, i wouldn't worry too much about wear in the mech - That car has one of the tightest gear linkages i have ever driven.
I think the problem was/is elsewhere..... :?
Meh, just keep drivin :D
PostPosted: Fri Nov 03, 2006 8:40 am
AHAHAHAHHAHAHA.
My 850 usually needs the 2-1 trick, I thought of it all on my own about a year ago and figured I was the only one doing it till I read this thread. I'M NOT ALONE ANYMORE!!!
Shard
PostPosted: Fri Nov 03, 2006 8:42 am
you guys..... adjust the bloody thing!!!
screw the little bolt in the clutch housing out 1 turn, pump the pedal a couple of times, then try getting it into 1st.... it may have magically fixed itself! - if it hasn't, then screw it out another turn
PostPosted: Fri Nov 03, 2006 8:45 am
I would not be happy with a gearbox that I had to select second before I selected first...
PostPosted: Fri Nov 03, 2006 8:58 am
Mine has a synchro lock on it that will only let me select first if i'm stationary. Half the time it doesn't release unless i'm still at the lights. If i'm at a stop sign and still creeping you have to do the 2-1, better then trying first and only getting it in 50% of the time, and the other half you almost end up stalling playing around.
Shard
PostPosted: Fri Nov 03, 2006 9:15 am
here here!!
I had the same issue. Had to go 2nd, then 1st when statinery. Adjusted the clutch and now right as rain! :lol:
PostPosted: Fri Nov 03, 2006 9:21 am
Shard
that's a 3 synchro gearbox.... the synchromesh ring just doesn't exist, your gearbox isn't designed to allow you to change into first while you're moving, same as reverse....
PostPosted: Fri Nov 03, 2006 10:43 am
I screwed it out 1 turn to begin with, it Seemed better with the engine running but not driving it, so brought it out 1 more turn. Will drive it after work.
Thanks guys.
Santo
"The Lone Ranger"
