Hi all,
This is not a plug for a business but just some information regardings prices and details as I know that the soda blasting aspect get raised here now and then.
I have recently been talking to John Crabtree of sodablast.com.au and he gave me details/quote on the soda blasting process. They charge $400.00 per hour and they can typically do both the inside and outside of a mini and all areas I mentioned (ie 5 rims and subframe) EXCEPT the underside in two hours.
Direct Quote
"If we can do the underside of your car within the two hours then we will go ahead and complete it. Otherwise we will call you at the 2hr mark with a progress report and you can instruct us to stop or continue at that time.
Interestingly, we thought that we were blasting a Leyland Mini a few weeks ago until we revealed a stamp on the roof that suggested the steel came from Australia. Any other form of paint removal would have lost this information for ever! I have attached a photo (the erased section has been sanded or grinded)
We have a drive-in facility at Taren Point in NSW and you will need to allow 3hrs from the time you drop it off to pick up. We currently need one week notice."
I am planing on getting my LS1275 worked on and repainted sometime early next year and will bring up the mini frame on a trailer from Canberra. A 3 hour turn around time is great for me as I don't have a need to either stay overnight or have a return trip back to Sydney at a later stage.
The next challenge would be to decide on whether I should repaint her in the original gold or go with another colour scheme
At least Canberra has a dry environment and I also have an empty spot in my 2 car garage so repainting her will not have to be hurried.
Now I need to work out what will need to be done with the engine.
Rob.
