Gerard wrote:
Hey Matt (and Everyone)
I put the housing back on yesterday afternoon and clutch arm hooked back in then got my next door neighbours 10 year old to come over and push the clutch in and I could not see/feel any movement of the clutch plate against the flywheel. Phoned Jack and his idea was to put the car in 4th back on the ground and put a crow bar in behind the clutch arm and push it out, see if i can get the car to roll (in gear) to rule out the pedal and hydraulics (I haver not tried this yet). Slave Cylider has not given me any grief and is not leaking so i am not sure if it is that.
ewww I forgot to measure the pin travel...
Pushrod doesn't move back when the pedal is in.
How would be the best way to measure the bearing carrier???
It is Rod Change - However when the engine is not running the gears can be changed so i assumed it would not be that linkage mechanism.
Cheers Gerard - Thanks again for everyones help
Firstly, just wanting to confirm you have set the clutch stop to the correct clearance? The book says 60 thou clearance butween the stop nut and clutch arm when you have the return spring off and the arm pulled back (bearing on clutch).
I run 30 thou clearance, not sure what is the best here tho.
When you say you could not see/feel any movement of the clutch plate against the flywheel, what do you mean? Like the bearing carrier wasn't travelling far enough?
To measure the travel of the carrier, use a set of vernier calipers (I have a broken set that will fit
) or a set of feeler gauges (then add up the total) between the end of the housing and the two big nuts. They are useful for something
What I'm trying to figure out is if there is enough travel at the release bearing to push the clutch diaphram in and release the clutch from the flywheel.
Have you got new clevis pins or checked the old ones for wear?
