Fitting a 12g295 head to an 1100 https://www.ausmini.com/forums/viewtopic.php?f=2&t=24417 |
Author: | mooman10_0 [ Fri Nov 03, 2006 5:00 pm ] |
Post subject: | Fitting a 12g295 head to an 1100 |
If fitting a 12g295 head to an 1100, which has been on a different 1100 motor, what mods need to be made? Thankyou |
Author: | simon k [ Fri Nov 03, 2006 5:08 pm ] |
no mods whatsoever..... it'll drop right on |
Author: | drmini in aust [ Fri Nov 03, 2006 6:10 pm ] |
.....but, unless you deck it by .080" or so, the C/R will be too low. They were used on 1098 Mk2A Sprites, and MG1100s, but these all had way less piston dish. Their C/R stock with the 295 was 8.9:1 I think. |
Author: | Wombat [ Fri Nov 03, 2006 6:43 pm ] |
I'm in the process of doing just that - looking for flat top pistons for 1100 to bring the CR back up will still need a little off the head as well> The 295 looks like it has been Vizardised and has unleaded seats and slightly bigger inlet valves. Will be using twin HS2 3 into 1 , double timing chain and RE13 cam. |
Author: | simon k [ Fri Nov 03, 2006 6:58 pm ] |
drmini in aust wrote: .....but, unless you deck it by .080" or so, the C/R will be too low.
They were used on 1098 Mk2A Sprites, and MG1100s, but these all had way less piston dish. Their C/R stock with the 295 was 8.9:1 I think. I didn't know that - learn something new every day - some days I learn lots.... ![]() David, how about getting some 998 pistons machined down? |
Author: | Wombat [ Fri Nov 03, 2006 7:18 pm ] |
Spoke with Paul Gulson today (former Leyland driver) he says he turns down 998 dished pistons to the bottom of the dish - discards the top ring and use a chrome ring as top (second slot) and cast iron next down Uses hypatecs then gave me a detail method to get 2 thou clearance between the piston and the cylinder wall. If I follow his method I'll go back to him and right it down ![]() |
Author: | mooman10_0 [ Fri Nov 03, 2006 8:39 pm ] |
Thanks guys, very helpful! ![]() |
Author: | mooman10_0 [ Fri Nov 03, 2006 8:42 pm ] |
What type of power increase would we expect, and what carb should I run? |
Author: | Wombat [ Fri Nov 03, 2006 9:24 pm ] |
A standard 1100 is shown as 45hp and my motor is a Vanden Plas and is rated at 55hp Probably mainly in the cam and maybe higher compression. I'm adding the twin HS2s and extractors into RC40 and adding twin chain timing - all things PG said to do and when I told him I was he just said "you go like a rocket" He also suggested a slightly hotter cam but I'll check the one in it before going fo the RE13. Paul also suggested 3.4 diff which will give me top power at 3K - great for passing in top gear on the highway ![]() If I can get another 10hp out of it I'll be happy |
Author: | Spaceboy [ Fri Nov 03, 2006 10:28 pm ] |
i think the 1100's had 50 hp? |
Author: | Wombat [ Mon Nov 06, 2006 6:02 pm ] |
Spaceboy wrote: i think the 1100's had 50 hp?
Checked my source - your right ![]() |
Author: | TheMiniMan [ Mon Nov 06, 2006 9:03 pm ] |
Hi David, sorry but my mate Archie didn`t have those flat tops,,, & dad is out of stock,,, but JP pistons in Adelaide used to do some 1100cc flat tops, give them a yell if you don`t follow Pauly Gs way. cheers |
