It is currently Mon Jul 28, 2025 4:17 am
PostPosted: Fri Nov 03, 2006 12:44 pm
Just busy rebuilding a set of Twin HS2's.
I have always wondered, but never asked.......what is this for?
PostPosted: Fri Nov 03, 2006 12:45 pm
teh admin God
teh admin God
Cigar holder?
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Fri Nov 03, 2006 12:51 pm
It could be an ancient form of torture. Stick your finger in and never get it out again! :lol:
PostPosted: Fri Nov 03, 2006 12:54 pm
ausmini mod
ausmini mod
Doesnt the hose go through there? Its on the heatshield right?
Peter.
PostPosted: Fri Nov 03, 2006 1:04 pm
Not on mine - If small enough is it the choke cable holder?
David L
PostPosted: Fri Nov 03, 2006 1:10 pm
Peter.
I thought that, but I have never seen a fuel hose going through there on others twin HS2's. It's about the right diameter. Is it supposed to be bent up like that?
Yes it's on the heatshield.
PostPosted: Fri Nov 03, 2006 1:22 pm
ausmini mod
ausmini mod
It does look a little bent :)
And yes, most dont have lines running through it even if its there :) maybe theres a few more HP by going around it :D
Peter
PostPosted: Fri Nov 03, 2006 1:31 pm
teh admin God
teh admin God
I don't have it on mine either.
PostPosted: Fri Nov 03, 2006 2:33 pm
it's for what I think is a small vacuum reservoir used by the vacuum advance dizzys, but not fitted to S's and GT's. You see them sometimes, a little round thingy in-line with the vacuum line
PostPosted: Fri Nov 03, 2006 4:22 pm
They were only used on early cars, 850 Cooper & Deluxe, on the vac line to the dizzy. I never did rip one apart to see what it is..... :lol:
PostPosted: Fri Nov 03, 2006 4:53 pm
As far as I know Kev, they are just an empty bulb, I think the idea is to act as a bit of a reservoir of vacuum as you are on and of the throttle, thus dampening any positive and negative pulses of vacuum / atmospheric pressure.
Did that any make sense??? :lol:
Sir Alec! we are not worthy!
PostPosted: Fri Nov 03, 2006 4:55 pm
were they only used on twins? I think it was on my 850 with 1 carb as well.
PostPosted: Fri Nov 03, 2006 5:05 pm
Yea, single on 850's was probably the most common, just off to shed, I think I have one knocking around, distributors often had screw thread on vacuum diagphagm to match metal pipe / nut with taper thingo!
997 and 998 were the twins, as S's didn't hav vac adv!! :P
Graham 8)
PostPosted: Fri Nov 03, 2006 5:07 pm
I think I've seen them on minors with 1 carb....
PostPosted: Fri Nov 03, 2006 6:03 pm
Heres a pic of the bulb thingo on one of our 850's:
It connects to the dizzy via the metal pipe
Here's the connection on a 997 cooper dizzy! :P
Graham 8)
