Best coil to buy for a clubman?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=24421
Author:  YoungMiniac [ Fri Nov 03, 2006 9:04 pm ]
Post subject:  Best coil to buy for a clubman?
I cooked my coil on my clubman tonighta nd wnated to know what coils you guys recommend buying new?
Cheers Ian
Author:  Hanra [ Fri Nov 03, 2006 9:09 pm ]
U cooked ur coil? Have u found the cause of this failure? Seems u have pulled to much current through it then? Did the coil need to have a ballast resistor in cct? Did u fit a ballast resistor to it?
Author:  YoungMiniac [ Fri Nov 03, 2006 9:23 pm ]
I tried to wire up a tacho, i have removed the wire so it wont do it again :P
Author:  Hanra [ Fri Nov 03, 2006 9:35 pm ]
Was connected to the neg side of the coil? Is it an aftermarket tacho? Did u use the green wire?
Author:  YoungMiniac [ Fri Nov 03, 2006 9:38 pm ]
Connect to -ve and it's a 3 gauge cluster from a clubman s...
Author:  Spaceboy [ Fri Nov 03, 2006 10:26 pm ]
did you cook your tacho?
Author:  YoungMiniac [ Fri Nov 03, 2006 11:14 pm ]
DOn't think so/ Hope Not
Author:  Spaceboy [ Sat Nov 04, 2006 7:22 am ]
bosch 8)
Author:  rainbowpython03 [ Mon Nov 06, 2006 6:37 pm ]
Bosch GT40 for me!
Author:  matt van'74 [ Mon Nov 06, 2006 6:57 pm ]
GT40 is what i run on both cars.
Does anyone know if the bling gold Lucas ones are any good? or worth the money?
