Do you know how old the shoes are?
no i dont, the car was purchased a couple of weeks ago and we are just getting an understanding of what needs work.
If everything there is correct, they will just need adjustment.
what does adjustment of the brakes involve? on my valiants (9" duo-servo drums), i need to remove the dust cover and turn the star wheel (part of the adjusting screw) while rotating the wheel slightly (car is jacked up). then i stop turning the wheel when slight resistance is felt in the rotating wheel (and back off the star wheel about a 1/4 turn to avoid brake drag during normal travel). does this sound like the same process for the mini's drums? I'm sure i'll be able to get through it, but any specific pointers are always appreciated.
where can i get replacement cylinders? i would also like to replace the flex-hoses, does anyone make some specifically for this morris mini? i'm sure wherever supplies the cylinders can also supply the shoes if so needed.
thanks poeee, i will check the mounting bracket and the clamp you mention at the steering column. is there anything else i can check prior to addressing the rack and pinion itself?
Steering is best fixed by getting an exchange rack from a reputable mechanic/steering specialist
once again, where can i find an exchange rack in the sydney area? is there any nationwide mail-order parts supplier of mini gear that i could get wallet-friendly with, or am i restricted to wreckers?
Is the steering column slipping on the pinion of the steering rack
i can't tell, is there some way to make sure, or is this sort of thing understood when you have the old rack on the bench and you are staring it at going "oh geez, thats why"?
The movement in the column itself is fixed by replacing the bushes in it
where are these bushings located, and where can i find replacements?
once again, thanks so much for your help so far guys, its much appreciated.
