It is currently Sat Jul 19, 2025 11:55 pm
 Post subject: Speedo Cable Replacement
PostPosted: Mon Oct 25, 2004 9:10 pm
OK, so I bought a new speedo cable for my '68 deluxe.
I then got very oily trying to disconnect it from the engine. How the hell do you undo the nut without taking things off? I can get my hand in there to turn it, but I can't undo it cos I can't get a spanner in there. I don't have any stubby spanners, but even with one it would be damn near impossible to do.
Does anyone have any quick and/or easy way of disconnecting and reconnecting a speedo cable?
Thanks
PostPosted: Mon Oct 25, 2004 10:29 pm
shouldn't have a nut, it's a knurled knobby sort of thing, it's done up finger tight - your new cable should be the same. Easiest way is with the radiator out - or at least the bottom radiator hose. Give it a good clean with degreaser and dry it out, clean your hands so you can grip the bastard and you might get it out :x
PostPosted: Mon Oct 25, 2004 10:39 pm
Put it on a %$^& hoist, you can attack it better from below. :wink:
PostPosted: Mon Oct 25, 2004 10:55 pm
Yeee ha, so Im not the only one who had trouble undoing there speedo cable!!!!! Yes a hoist would make life a lot easier.
PostPosted: Mon Oct 25, 2004 11:03 pm
I have it up on ramps, so I can attack it from below.
I can get my hand in around the drive shaft but there's no way I can get any of my spanners in there.
And it definately has a nut its 7/8 and its not done up finger tight, or if it is, its tighter than my fingers can turn.
It would definately be easier with the radiator out as the lower hose is in the way. I might try that and replace my radiator at the same time.
What a ^%@$ of a job.
PostPosted: Mon Oct 25, 2004 11:04 pm
Thanks
Yer Baby I know where you R comming from... :roll:
Nope no Easyway........get rid of the radiator.....Yer that's a pain init's self.. :idea: Degreaser and then some More and then some more and a high pressure hose..... Get you'r hand down their with a rag, then the tighten the new cable as tight as0 you can get it....Engine out is always the best way... but always not possible.. :lol: 4me it was...
I have learnt the bottm end that goes to the Gearbox come in many ways... :!: :?: :? :idea: :arrow:
Degres and clean it of with a nice pressure hose... :?: and then replace
Edited...what was I thinking :!:
PostPosted: Tue Oct 26, 2004 6:32 am
From the top, if you pull the rad and hose out you can just get a pair of multigrips onto the knurled nut.. at least I did, a long time ago.
Users browsing this forum: Bing [Bot] and 76 guests
