cam https://www.ausmini.com/forums/viewtopic.php?f=2&t=24595 |
Author: | dale 62 [ Tue Nov 07, 2006 3:24 pm ] |
Post subject: | cam |
hey what does a slot drive cam mean? i have a 1275 from a 1100s what type cam would i be looking for |
Author: | Stuwey [ Tue Nov 07, 2006 3:49 pm ] |
That would depend on what sort of oil pump you have.... |
Author: | Matt68 [ Tue Nov 07, 2006 3:52 pm ] |
It would have come with a spider drive cam from the factory. I believe there were three main types of 'driving' the oil pump, that is, how the end of the cam shaft connects to the oil pump. Pin drive, with a pin in the end of the cam, and a slot in the oil pump drive to fit over it, early morris and cooper s type. Spider drive, as fitted to 1100s 1275 motors and later mini motors (i think?) Has a small 'gear' on the oil pump, with a small piece called the spider which sits on this and fits into the end of the camshaft. Bad news if dropped into the gearbox! Slot drive, with a slot in the end of the cam, more modern A series engines, UK from mid 70's (I think) Cheers Matt |
Author: | drmini in aust [ Tue Nov 07, 2006 6:25 pm ] |
Right now the `spiders' as used on 1100S are NLA (no longer available) so if you have one don't lose it. You can put a slot drive cam into any A series, you just need to get a `slot drive' oil pump to go with it. ![]() |
Author: | dale 62 [ Tue Nov 07, 2006 6:57 pm ] |
thanks for all the info!!!! well appreciated ![]() |
