awdmoke wrote:
It's not unheard of for the fan to be fitted backwards accidentally,
then it cools fine when stationary, but struggles at cruising speed
as the fan fights against the natural air flow
But, that said, I've had plenty of cars that do that, not just minis/mokes.
Usually just a slightly blocked radiator core (or dodgy water pump).
Idle is fine, but placed under load for more than say 3/4 hour
it builds up more heat than the radiator can shift.
Turning the fan round won't change its helix angle direction.
If you fit the fan backwards, it still blows INTO the guard, but less efficiently.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
