empty fuel lines https://www.ausmini.com/forums/viewtopic.php?f=2&t=24657 |
Author: | Blokeinamoke [ Thu Nov 09, 2006 8:15 am ] |
Post subject: | empty fuel lines |
How many turns does it take approx to get fuel from the tank to the carb with empty fuel lines? This assuming a primed carb.. |
Author: | simon k [ Thu Nov 09, 2006 8:20 am ] |
turns? you mean turns of the engine with a mechanical pump? it ought to gravity feed most of the way, and a little bit to push it up behind the motor.... can't answer though, I use electric pumps ![]() |
Author: | Blokeinamoke [ Thu Nov 09, 2006 8:24 am ] |
skssgn wrote: turns? you mean turns of the engine with a mechanical pump? it ought to gravity feed most of the way, and a little bit to push it up behind the motor.... can't answer though, I use electric pumps
![]() Yep the mechanical. The gravity feed is less on a moke because the tank is lower |
Author: | sports850 [ Thu Nov 09, 2006 8:38 am ] |
If the carb is primed it should draw enough fuel from the initial startup , maybe prime the carb twice and run it and it should be there . Also , if you're still having trouble , take the fuel line off the pump on the tank side and let it sit for a while so it gravity feeds to just below the fuel pump , then connect it and try again , just in case the pump is too dry to draw the fuel the full lenght of the line . Is there any filter in the way ? Maybe take the fuel tank off the mower and wire it above the engine bay to start the motor that way with a length of hose from the fuel pump to a bucket so the carb has fuel and the pump can freely draw the fuel . Electric pumps are so much easier though ... |
Author: | Blokeinamoke [ Thu Nov 09, 2006 8:41 am ] |
Cool, should have start tomorrow ![]() |
Author: | sports850 [ Thu Nov 09, 2006 8:43 am ] |
Woohoo , a start followed by a burnout on your neighbours lawn I'm sure .... |
Author: | Mike_Byron [ Thu Nov 09, 2006 8:56 am ] |
My mini has a mechanical fuel pump and i have run out of feul in a couple of times. I just use some aerostart in the throat of the carby and the motor will start and run for a few seconds. Then I do the same thing again and possibly even a third or fourth time. By then the engine has made the fuel pump suck and push fuel into the carby and the car is running normally. I do this because the starter motor is not whining away and drawing too much from the battery. I leave a couple of seconds between bursts of aerostart and restarts because i dont want a blow back of burning ether to ignite under the bonnet. But it doesn't take very long to get the fule up into the carby bowls. |
Author: | simon k [ Thu Nov 09, 2006 9:37 am ] |
I can actually drive about 1km on just the fuel in my fuel bowls (twins) - I know cos I can hear when the electric pump goes mad, and about 1km after that I stop... usually very close to the petrol station ![]() so if you fill up the bowl, you ought to have there to start and run for a few minutes, so plenty to get the fuel up from the tank... |
Author: | Blokeinamoke [ Thu Nov 09, 2006 12:39 pm ] |
sports850 wrote: Woohoo , a start followed by a burnout on your neighbours lawn I'm sure ....
no brakes yet, so not quite yet, but I will be starting with no exhaust and the garage door open. I think I might need to rev it out as well ![]() ![]() |
Author: | Morris 1100 [ Thu Nov 09, 2006 5:29 pm ] |
If you fill the float bowl on the carby it should pull the fuel up before it runs out. |
Author: | 9YaTaH [ Thu Nov 09, 2006 7:29 pm ] |
Post subject: | Pre oiled Fuel |
sports850 wrote: Maybe take the fuel tank off the mower and wire it above the engine bay to start the motor that way with a length of hose from the fuel pump to a bucket so the carb has fuel and the pump can freely draw the fuel . Electric pumps are so much easier though ...
But first check if your mower is a four stroke ![]() |
Author: | Blokeinamoke [ Thu Nov 09, 2006 7:36 pm ] |
Post subject: | Re: Pre oiled Fuel |
9YaTaH wrote: sports850 wrote: Maybe take the fuel tank off the mower and wire it above the engine bay to start the motor that way with a length of hose from the fuel pump to a bucket so the carb has fuel and the pump can freely draw the fuel . Electric pumps are so much easier though ... But first check if your mower is a four stroke ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | sports850 [ Thu Nov 09, 2006 9:42 pm ] |
Nahh , don't worry about that , if it's two stroke just wait till the winds blowing towards your neighbour's place . |
