850 Door Cards
https://www.ausmini.com/forums/viewtopic.php?f=2&t=24671
Author:  minimetoy [ Thu Nov 09, 2006 1:23 pm ]
Post subject:  850 Door Cards
Guys,
Did the 850's come out with a door card glued to the outer skin (on the inside of the door) or was it just the material (vinyl) that was glued to the door skin??
Dan
Author:  graham in aus [ Thu Nov 09, 2006 2:12 pm ]
850 (and 997) door cards were a plain coarse vinyl bonded (backed) with a horse hair / hessian type sound deadener material. these were glued onto inside of the doors, with folded (vinyl covered) thick card trim pieces at each end to hide edges and door inners. There was also a thick card liner screwed into the bottom of the door pockets.
Do your doors have proper drain tubes? if not the doors tend to fill with water and rot everything! :roll:
Author:  minimetoy [ Thu Nov 09, 2006 2:25 pm ]
Cheers Graham.
I'll check my drainage hole too.
Dan
Author:  dove grey 64 [ Thu Nov 09, 2006 6:32 pm ]
you can make up door cards easy
or get me to make them up for you :)
