turbo/supercharged minis https://www.ausmini.com/forums/viewtopic.php?f=2&t=2476 |
Page 1 of 3 |
Author: | Sorceress [ Sun Oct 24, 2004 6:06 pm ] |
Post subject: | turbo/supercharged minis |
ok, i am looking at upgrading my mini. who here has a turbo/supercharged mini, and can u give me a breif run down on costs, parts, how u went about it etc etc |
Author: | 9YaTaH [ Sun Oct 24, 2004 6:22 pm ] |
Post subject: | Re: turbo/supercharged minis |
Sorceress wrote: ok, i am looking at upgrading my mini.
who here has a turbo/supercharged mini, and can u give me a breif run down on costs, parts, how u went about it etc etc Welcome Sorceress, people don't generally go the Turbo route for the road with the A Series....gearbox is the weakest link! Supercharging is considered a better way to go....and kits are available from Link Automotive in Melbourne (for example). A turbo engined conversion like the Toyota Starlet is another way to go. How about Suzi GTi? I don't know if either is really worth the trouble when there are so many other more "conventional" ways to make your Mini go-fast. Search on Turbo and you will find heaps of opinions ![]() |
Author: | sg [ Sun Oct 24, 2004 6:48 pm ] |
Sorceress.... have a chat to Low'n'Blown and SC850 on here... they are the encyclopaedias on this sort of thing..... |
Author: | drmini in aust [ Sun Oct 24, 2004 7:01 pm ] |
Also kazjim- has a 998 turbo, and boostedmini- has a 1400? turbo. ![]() |
Author: | minimarc [ Sun Oct 24, 2004 8:42 pm ] |
probably a good way to go is to find someone whos getting a bit a stuff in from england and get a 1275 metro turbo donk put in there crate turboing is cheaper way to go as supercharger kits are pretty pricey but i think there was a subaru one people where using that sounded ok and reasonable but easy to get a litttle turbo from a jap auto spares / wreckors and plonk it on same things need to be done as with any other engine change compression ratio etc on low boost shouldnt worry a good condition gearbox as long as not flogged ![]() |
Author: | low n blown [ Sun Oct 24, 2004 9:48 pm ] |
Mate I recently sold a turbo engine to a guy on the Sunshine Coast, hopefully he gets online here as I dont have any photos of the engine and it was a sweeeeeet bit of equipment. I sold it as a complete unit for $4500 and everything was there, but hadnt been run for a few years. As for which one to go for. The turbos are a bit difficult as you are limited for space to cool the thing unless you dont mind chopping into your car a bit. It doesnt really matter which route you go, as soon as you make big power the box will always be the weak point. As long as you are not brutal with your shifts and opt for a decent box ie 4sp straight cut or better if you have the money should hold together. Prices vary. Power costs money if you want it to be reliable. My turbo motor cost around 8k complete and my supercharged unit owes me 11k, but if I did it again would cost me a lot less as RnD was a bit expensive. Any Q's drop me a line. |
Author: | minimarc [ Sun Oct 24, 2004 10:30 pm ] |
i quess it all depends on what you want if you want serious power then money is the name of the game if you want a fun little engine then i would go with a turbo install Very similar to a guy on her Kazjim where he plumed the whole thing together a bit differently then normal put the turbo basically over the clutch area of the engine if i remember This way meant no body cutting Cooling allways a prob with any powerfull mini engine but can be handled with a decent rad and small intercooler. I dont know if id bother going down the way of straight cut gearboxes etc unless your going to race it of you want a big big power machine Cheap way NOTE there is no cheap way loll get a decent 998 or 1100 strengthen up the internals get crank treated, centre main straps, correct compression ratio decent pistons JPs or something, high flow water pump, fuel pump get a small turbo or a charade or something get a manifold and plumbing made up whack it together Rebuild box if needed |
Author: | supercharged 850 [ Mon Oct 25, 2004 12:21 am ] |
IMHO - Its all a waste of money.... If you want a cheap turbo'd car, buy a silvia, and use the money you've saved on a new paint job for the mini...... The A series drivetrain just cant cut it. Just the opinion ive come to, after much R&D. |
Author: | drmini in aust [ Mon Oct 25, 2004 6:28 am ] |
supercharged 850 wrote: IMHO - Its all a waste of money....
If you want a cheap turbo'd car, buy a silvia, and use the money you've saved on a new paint job for the mini...... The A series drivetrain just cant cut it. Just the opinion ive come to, after much R&D. So, what breaks in the drivetrain? I know boostedmini is running a rebuilt K box in his 1400? turbo, nothing's broken yet. And kazjim is still running a stocko rodchange, ditto. These are both road cars, I guess for draggin' you might need something stronger...? |
Author: | kazjim [ Mon Oct 25, 2004 8:56 am ] |
Yea, Turbo 998 here.....(Sorry, been quiet lately.....But I'm back) AS Doc said, I'm running a STOCK clubbie rod-change in mine, not real sure about the DIff, but we think its a 3.76:1 ish ratio.... 4000RPM on the freeway=105ishkph ..... I DO thrash it mercilessly, but i try to limit my take-offs to the lower-end of the squealing and smokeshow.......(3500RPM Takeoffs, slide clutch...) The Biggest hassle I'm having at the moment is clutch slip, while the HP isnt massive, the Torque on these is phenominal, I'm running a "Blue" diaphragm and it slips just about everytime going into 4th under boost..... time to get an Orange methinks..... I have thought about the Turbo/SC argument and while I'm running a Turbo, i think a SC MAY be better in some situations, like traffic and city driving.. but on the Freeway, i can just ease up the pedal, drop the boost and get the fantastic economy of a 998 with a largish cam....(about 40Mpg) under boost well, lets just say its about 5Mpg !! J |
Author: | cush [ Mon Oct 25, 2004 9:36 am ] |
kaz... is it you with the turbo sitting above the flywheel housing?. . if so... you got pics of it? ![]() ta |
Author: | kazjim [ Mon Oct 25, 2004 9:45 am ] |
![]() Got more at home, drop me an email, I'm happy to send them ! J |
Author: | cush [ Mon Oct 25, 2004 9:46 am ] |
that looks crazy with the stock filter hangin upside down ![]() pm sending... ![]() |
Author: | kazjim [ Mon Oct 25, 2004 9:49 am ] |
Yea, thats a really old pic, now running a Unifilter and there is an extra radiator in the front as well as a lot of piping changes..... I'll try to get a more recent pic online soon...... just been busy.... J |
Author: | min13k [ Mon Oct 25, 2004 12:05 pm ] |
seen this car in the flesh bit agrocultral (?) in the turbo design but from what the good doctor told me it flys makka |
Page 1 of 3 | All times are UTC + 10 hours |
