Repairing LH A pillar rust holes..
https://www.ausmini.com/forums/viewtopic.php?f=2&t=24840
Author:  drmini in aust [ Mon Nov 13, 2006 7:17 pm ]
Post subject:  Repairing LH A pillar rust holes..
I have had an issue with rust on the LH A pillar next to the screen, there are a couple of small holes so I want to cut the rot out and parch it with the MIG.
RH side I would have no qualms about doing, but the LH one has the wiring in there.
Any easy way to pull the wiring up out of the way via the interior light hole, and yank it back down after?
I have the 1 piece stuck in headliner.... and I'm damned if I want to remove it.:cry:
Author:  buztoy [ Mon Nov 13, 2006 7:25 pm ]
excuse me doctor, but whats wrong with unplugging it at either end and welding the thing, if the wiring doesnt work replace it, you might be lucky and have no probs at all,
feels like going "dr what happens when you swallow detergent"
Author:  drmini in aust [ Mon Nov 13, 2006 7:34 pm ]
I had an issue once before with wiring shorting in there in my old S, driving along and car filled with smoke- so I'd rather not tempt fate.
If I knew it was away from the arc, OK.
Maybe I can bung something in there to protect the wiring, then weld it. :)
Author:  buztoy [ Mon Nov 13, 2006 7:45 pm ]
how big is the rust hole maybe you can poke the protection through the rust hole,
pin hole definition changes from person to person,
Author:  Mike_Byron [ Mon Nov 13, 2006 7:45 pm ]
Wet waste cloth over the wires and under the cutout perhaps attached to a tie wire that can be pulled out like a ummmm... dare i say it ...... tampon
Author:  drmini in aust [ Mon Nov 13, 2006 7:51 pm ]
Mike,
Hmmm yes- maybe I could pull it out downwards thru that hole in the A pillar....
Buztoy,
Holes will be 15mm dia by the time I enlarge them.
I could just bog them now, but we know what happens then... :lol:
Author:  Gadgets mini [ Mon Nov 13, 2006 9:50 pm ]
Doc
if the holes are going to be 15 mm you could poke some of thet thermo tec fiberglass heat sheild stuff in over the cables then weld up and hopefully teh Fiberglass stuff will protect it or could you inject some manifold cement in to insulate the cables??
just a couple of ideas
Author:  TurboOrangie [ Tue Nov 14, 2006 3:23 am ]
Maybe you could get somebody to TIG it up for you too keep the heat down.
Author:  9YaTaH [ Tue Nov 14, 2006 5:42 pm ]
Post subject:  fiberglass heat sheild stuff
Gadgets mini wrote:
Doc
1071 was rabbiting on about a welding "clay" today that you form around the area to be protected....I have no eye deer what it is called :roll:
Author:  drmini in aust [ Tue Nov 14, 2006 6:19 pm ]
I have acquired some dense fibreglass matting at work, if I slot between the holes I can get in there and pack the wires away with it to the other side. Then make a decent patch.8)
Author:  Zizzle [ Tue Nov 14, 2006 9:15 pm ]
Don't forget to take some pics and show us how it's done.
Author:  drmini in aust [ Tue Nov 14, 2006 9:35 pm ]
Windscreen out job, of course. :wink:
Or maybe leave in, with luck it'll break then and I can get a newer (non pockmarked) one!!
Author:  mickmini [ Tue Nov 14, 2006 9:51 pm ]
get a bit of another wire (does not have to be electrical, as it is just to take the heat), twist ends together and tape over the joint, to the top end or bottom end whichever is shorter. pull through until the new disposable wire is in the space under the weld. do the weld and then just pull the original wire back into place.
you might consider just doing this with a new wire after the welding to ensure that the wires are good anyway.
michael
Author:  Wombat [ Wed Nov 15, 2006 6:09 am ]
Post subject:  Re: Repairing LH A pillar rust holes..
Don't think they would pull too easy - too mant bends. What about PUSHING? Use the good old coat hanger,- attach end of wires and push then up the pillar past the holes - leave in place while welding then pull back down.
Author:  minimalist_1 [ Wed Nov 15, 2006 7:23 am ]
Doc.
I have done some welding with the mig near my wires before. I used some ehaust tape to wrap the wires to protet them, worked a treat. If you dont have any you could get a fire blanket from bunnings or supercheap, The type you use in the kitchen. Would do the job i think.
